jalen Posted June 26, 2012 Report Share Posted June 26, 2012 So i went to go sell my Hp probook 6555b laptop and called tech service to make sure i factory reset it the right way. They told me to do a disk sanitation on it. 16 hours later it is complete i went to go turn on now i keep getting a disk error press any key to restart. before it goes to the disk error on start up it says media failure please check cable pxe-e61 on the startup. have a guy cumming tomorrow to buy it so any help would be great. Quote Link to comment
Boaty Posted June 26, 2012 Report Share Posted June 26, 2012 The reason it is saying PXE error is because it is set up for network boot. This is what you need to do. It may be different on your end, but it'll be slightly different for every laptop - but, the theory is the same. At boot up, you need to start BIOS/Setup. Once you're there, look for boot setting configuration (could be boot order, boot devices, etc). It will have a heirarchy of different options. Usually it'll show a DVD/CD drive, a hard drive (HDD), USB, Network (PXE), etc. You need to set it to HDD as the first boot device, and if you can disable Network boot entirely, do so. It's almost never used, and certainly not by any home user. That's corporate stuff. Default is usually removable storage, such as a DVD or USB key, but for the sake of simplicity (and not having to check for a device at startup) just set the first boot device to your hard drive. Reboot, and it should work. Some how, it has set network boot as the first boot device. As I said, it's never used. But if it's set to primary/1st boot device, it will give you that exact problem. Hope that helps. If it doesn't, please send me a PM, or reply in this thread. I'll check it out throughout the evening to see how things went. Quote Link to comment
Boaty Posted June 26, 2012 Report Share Posted June 26, 2012 In addition, you can also reset back to default configuration. Usually this will be labeled in the BIOS as "Set System Defaults" or "Load Setup Defaults". Can also be labeled as "Failsafe Defaults". Most settings other than the default won't help any, and is going to be the burden of the new owner any ways. On a desktop system it's more prudent to go in and change settings around (there's a lot more configurable variables than a laptop). But for laptops, defaults are generally the only setting worth using. Some BIOS' don't include a boot device priority, and you can only change boot devices during startup via a different menu. (Such as "ESC - Boot Devices")... the defaults will be what the BIOS is set to right from the factory. Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 so on boot order its set for network hdd network upgrade bay usb floppy usb cd-rom usb hard drive notebook ethernet sd card dock upgrade bay this is correct? and went i set it to default the network upgrade bay is one above the network hdd still doesn't work. Quote Link to comment
Boaty Posted June 26, 2012 Report Share Posted June 26, 2012 This is what your boot order should be set to (using the list of options you provided above) USB Hard Drive USB CD-Rom (This can be on top too, allows you to boot from CD automatically, if no bootable CD is present, it moves to the next on the list, which should be your HDD) SD Card Notebook Ethernet Dock Upgrade Bay Network HDD Network Upgrade Bay I am curious as to why it doesn't show a Hard Disk Drive other than USB HDD. Is this a netbook? It should show a hard drive that isn't USB, and it should be the very top of the list. Try setting it the way it is above, and see if it works that way... it IS possible that you have a bad hard drive (hence why it doesn't appear in that list) and the BIOS isn't detecting it. Very, very rare case though (but not unheard of... they DO go out). Try that and see, Jalen. EDIT: If the above doesn't fix the issue, search the BIOS to load setup defaults/failsafe defaults. Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 i did a hard drive test and it passed but i will try the configuration. Quote Link to comment
Boaty Posted June 26, 2012 Report Share Posted June 26, 2012 Yep set it to defaults, will probably fix the issue. I wonder how it managed to get set on PXE boot? (Network Boot = PXE) Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 configuration didn't work getting the same thing. Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 i was wondering if i should have the UEFI boot mood selected? Quote Link to comment
Boaty Posted June 26, 2012 Report Share Posted June 26, 2012 hmm. very odd. At boot up, does it allow you to choose boot device? It would be a key press that brings up the menu... usually ESC or F10. Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 esc brings system menu f10 is bios settings Quote Link to comment
Boaty Posted June 26, 2012 Report Share Posted June 26, 2012 Try esc, and then see if there is a list of boot devices. Choose HDD if it's present... I am wondering why it's doing that >.< Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 i called tech support again and they said enable the uefi and when i did that it said i need to clear the tpm, should i do that? Quote Link to comment
Laecaon Posted June 26, 2012 Report Share Posted June 26, 2012 Laptop has a harddrive from the factory. The fact that the bios does not see it is very odd. Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 and tech support is no help, i was teaching them how to get to the bios settings. Smh Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 i did some tampering and now the configuration is so on boot order its set for 1.network upgrade bay 2.notebook hdd 3.usb floppy 4.usb cd-rom 5.usb hard drive 6.notebook ethernet 7.sd card 8.dock upgrade bay so the harddrive is showing up Quote Link to comment
Boaty Posted June 26, 2012 Report Share Posted June 26, 2012 Yeah. Welcome to HP. Now try dealing with them all the time like I do. It's funny this is happening because I am currently dealing with an HP laptop (Presario F500) with a wireless issue. Wireless simply won't work... found out from tech support that it's a known issue and since this model (and the F700) were so short-lived (wonder why) that it was never recalled but would be replaced by a new (bad) one via warranty. :/ I'm a fan of Dell, personally - they seem to have the least amount of issues, at least in my trade. I've had my fair share of warranty issues with almost all brands. Acer being the worst. Toshiba isn't much better. Dell, as long as it's in warranty, is always the best and easiest to deal with. HP on occasion gives me a smooth warranty process but sometimes they can be a real pain in the ass. That, and I can't generally understand most of the tech's... I don't speak Dirka. TPM stands for "Trusted Platform Module", and it's a security thing built into some commercial-class laptops. Usually there is an option in the BIOS to clear this. Sometimes there isn't. I'm not familiar with that model off-hand, but try google and see if you can come up with something. It's possible the reason the HDD isn't showing up is because it's been locked out by a password, hence the TPM prompt. At this point I am not sure exactly how to help you, without having it in my hands and looking at it myself. Is the laptop still under warranty? I'd honestly try to just get it replaced if you've exhausted all other options. Else, continue to deal with technicians over the phone until you find a solution. It's not unheard of for me to go through 3 or 4 tech's before finally getting what I wanted. In the end if it's under warranty, just demand a replacement. Quote Link to comment
Laecaon Posted June 26, 2012 Report Share Posted June 26, 2012 Stop putting the network options at the top of the list. Put the hard drive at the top if it now shows up. That is where your OS is installed. 1 Quote Link to comment
Boaty Posted June 26, 2012 Report Share Posted June 26, 2012 Also, set the first boot device to notebook HDD if you can. That was the original goal, after all. As I said before, you want all network boot options to be either disabled/removed from teh list entirely, or set to the lowest priority (bottom of the list). Your first boot device should be set to Notebook HDD. That's the important part. Having network upgrade bay set to the first boot device is what is likely preventing you to boot. Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 i dont have a warranty i bought it of craigslist. used for awhile. after i did a disk sanitation, i get this stupid error Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 It says it is exiting pxe rom now? Quote Link to comment
DAT510 Posted June 26, 2012 Report Share Posted June 26, 2012 You wiped the HD clean? Did you delete the OS? lol. Quote Link to comment
metalmonkey47 Posted June 26, 2012 Report Share Posted June 26, 2012 Did you try clearing the cache on your flux capacitor? Quote Link to comment
DAT510 Posted June 26, 2012 Report Share Posted June 26, 2012 Did you try clearing the cache on your flux capacitor? I did that and it gave 6gb of ram. No joke, defrag your cache on the flux. I can play Arma at full settings now. Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 How do you do that? Quote Link to comment
