shugga510 Posted June 5, 2012 Report Share Posted June 5, 2012 Hi i'm in the process of swapping a KA24de in my 510 and i've been reading about using the 620 motor mounts. I was wondering what year 620 mounts should I use and I also see that the left and right side mounts are different. Do I use both right side mounts or use the left and right side mounts? thanks Quote Link to comment
datzenmike Posted June 5, 2012 Report Share Posted June 5, 2012 If you mean the metal brackets, I can't see how they will work. The L motors are tilted about 23 degrees over to the right from the position of the KA motor. The Z series motors have the same orientation as the KA. Perhaps those from a Z24 as it's the same height as the KA?. Quote Link to comment
ggzilla Posted June 5, 2012 Report Share Posted June 5, 2012 Do you mean the rubber isolators? Quote Link to comment
shugga510 Posted June 6, 2012 Author Report Share Posted June 6, 2012 yes, i do mean the rubber insulators from the 620. I have read that some use the stock 510 insulators with the KA brackets. Others use the 620 insulators along with the KA brackets as well. My question is im looking to use the 620 insulators and I was wondering if you use both the left and right insulators or do you have to buy 2 right sight insulators because the left and right are different. hope that makes sense. Quote Link to comment
ggzilla Posted June 6, 2012 Report Share Posted June 6, 2012 510 insulator 620 early insulator 620 late insulator Quote Link to comment
shugga510 Posted June 6, 2012 Author Report Share Posted June 6, 2012 thank you for clarifying between each mount. My question is if I wanted to use 620 mounts do I use the late insulators or the early insulators? I am planning to buy the mounts from oreily/ kragen and the left and right mounts are different. Do i order both the left and right insulators or do I order 2 right side insulators? sorry if my questions seem really vague or redundant. thank you for all of your help. http://www.oreillyauto.com/site/c/search.oap?year=1977&make=Nissan&model=620&vi=1210138&keyword=engine+mount+ Quote Link to comment
ggzilla Posted June 6, 2012 Report Share Posted June 6, 2012 Good questions. I do not know the answer. Quote Link to comment
]2eDeYe Posted June 6, 2012 Report Share Posted June 6, 2012 You want to use the late isolators. :) Quote Link to comment
shugga510 Posted June 6, 2012 Author Report Share Posted June 6, 2012 okay thank you, so use the late insulators and use the left and right side? Im planning on purchasing them from oreily/ kragen do i order both left and right? http://www.oreillyauto.com/site/c/search.oap?year=1977&make=Nissan&model=620&vi=1210138&keyword=engine+mount+ Quote Link to comment
]2eDeYe Posted June 7, 2012 Report Share Posted June 7, 2012 Yep you'll need both. You might PM Icehouse to find out what mods are needed exactly. I've supplied him with 620 mounts to do the swap into a 510 before, he's done the swap a few times with the 620 mounts. :) Quote Link to comment
shugga510 Posted June 7, 2012 Author Report Share Posted June 7, 2012 thank you for all of your help Quote Link to comment
