ChevelleDude71 Posted June 23, 2013 Author Report Share Posted June 23, 2013 looks awesome Thanks! I'd trade it all for your engine! worked on getting the headlights working today. After by-passing the relay and fixing some grounds I discovered another thing about my car that I shouldn't be surprised about... the previous owner wired all four lights to work in the low beam setting AND I have no high beams. So the question is do I rewire it to the factor setup or just make the outside headlight switch to the brighter filament with the high beam switch? I"ll probably just leave it for now and fix it later... Next I started replacing the 1/4 window weather seals..... I immediately regret this decision, these things are tedious especially when you buy the cheaper straight weather seal, if I had to do it again i would buy the nice one piece molded seals... One side done, I might do the other side tomorrow. Quote Link to comment
fisch Posted June 23, 2013 Report Share Posted June 23, 2013 Wow, this thing is fantastic. And such a ballzy color. Thumbs up man! Quote Link to comment
ChevelleDude71 Posted June 23, 2013 Author Report Share Posted June 23, 2013 Wow, this thing is fantastic. And such a ballzy color. Thumbs up man! Thanks! It was between Kawasaki green and the S2000 Apex Blue. So either way it was going to be bright. I love how the green turned out. I put the lights and grill in today, still need to fix the wiring to the side markers and the front ambers. 1 Quote Link to comment
ChevelleDude71 Posted June 28, 2013 Author Report Share Posted June 28, 2013 Before buffing it out .....standby after pics coming soon.. 2 Quote Link to comment
yellowdatsun Posted June 29, 2013 Report Share Posted June 29, 2013 Looks like Optimus Prime sound deadening! Quote Link to comment
banzai510(hainz) Posted June 29, 2013 Report Share Posted June 29, 2013 I would fix the wiring. Its pretty simple. then you can buy a H4 harness and plug in to the stock plug Quote Link to comment
ChevelleDude71 Posted June 30, 2013 Author Report Share Posted June 30, 2013 I would fix the wiring. Its pretty simple. then you can buy a H4 harness and plug in to the stock plug I'll Probably end up doing that. H4 housings are pretty affordable and a lot brighter. Quote Link to comment
ChevelleDude71 Posted August 2, 2013 Author Report Share Posted August 2, 2013 Hood reflection, thought it was a cool shot. good enough for now, I'm just ready to put it together already. 1 Quote Link to comment
aintnobiscuit Posted August 2, 2013 Report Share Posted August 2, 2013 Looking good Quote Link to comment
NaudiS4 Posted August 2, 2013 Report Share Posted August 2, 2013 Looks great....the PO of my car did the same thing with the headlights. I still need to fix it. Quote Link to comment
ChevelleDude71 Posted August 10, 2013 Author Report Share Posted August 10, 2013 put the bumpers back on, and started the wiring for the lights. 2 Quote Link to comment
ChevelleDude71 Posted September 13, 2013 Author Report Share Posted September 13, 2013 Alright I'm stuck. I have been kicking around how to make this car more driveable. the current L16 is all good except for the carb that is just plane worn out, I rebuilt it and it just doesn't run like I would like it to. So here the question do i: 1) Spend 200 bucks on a new webber carb, and drive the L-16 till it breaks, (Which might take a while) (and hate how slow it is) or 2) Spend 1000 to buy a KA24de (I would just buy 240sx crap car, use the tranny and rebuild the engine, junk/sell the rest) or 3) Spend 1300-1400 to buy a CA18DET (I like the power potential, and the smaller displacement for HOPEFULLY some good MPG so I could drive it to work, which is around 70 miles round trip) What do you guys think? Quote Link to comment
rusty12ver Posted September 14, 2013 Report Share Posted September 14, 2013 Buy webber, drive car, then buy ca/Ka, rebuild newly aquired engine. It will surely need to be gone through. Ca is at least 24yrs old. Not exactly "low mileage" engines anymore. Quote Link to comment
ChevelleDude71 Posted September 14, 2013 Author Report Share Posted September 14, 2013 Buy webber, drive car, then buy ca/Ka, rebuild newly aquired engine. It will surely need to be gone through. Ca is at least 24yrs old. Not exactly "low mileage" engines anymore. That's true, with either engine I was planning on going through them. Quote Link to comment
sjsilvera Posted October 8, 2013 Report Share Posted October 8, 2013 Alright I'm stuck. I have been kicking around how to make this car more driveable. the current L16 is all good except for the carb that is just plane worn out, I rebuilt it and it just doesn't run like I would like it to. So here the question do i: 1) Spend 200 bucks on a new webber carb, and drive the L-16 till it breaks, (Which might take a while) (and hate how slow it is) or 2) Spend 1000 to buy a KA24de (I would just buy 240sx crap car, use the tranny and rebuild the engine, junk/sell the rest) or 3) Spend 1300-1400 to buy a CA18DET (I like the power potential, and the smaller displacement for HOPEFULLY some good MPG so I could drive it to work, which is around 70 miles round trip) What do you guys think? i have an 82 210 2 door sedan with an sr motor in it. very easy installation, did not need to cut the firewall, only the re positioning of the hole in the tunnel for the shifter. stock is about 160hp. and they are all over the internet from $900 - $1600 for the turbo ones. i used a 200sx cross-member and it fitted in perfectly. i believe the 510 and the 210 were built off of the same chassis and the dimensions are very similiar. if you go with the SR20VE then that is closer to 200hp stock, but you may have to cut your firewall. the distributor and solenoids for the variable valve timing are at the back of the motor. my build thread here in jamaica: http://www.wheelsjamaica.com/wheels_forum/index.php?topic=185964.0 Not anywhere near finished but you will see what i have done so far. the stock sr motor is so much fun to drive which is why i have not finished the car yet. I wish you all the luck in your build and i hope you make the right decision on the motor. All the best!! Quote Link to comment
ChevelleDude71 Posted October 24, 2013 Author Report Share Posted October 24, 2013 Thanks for the advice, I found a super killer deal on a ka24de with tranny. So ill be picking that up tomorrow. There will be a rebuilt L16 with 5- speed for sale in the next couple of days (so I can fund the rest of the parts needed) Quote Link to comment
ChevelleDude71 Posted October 26, 2013 Author Report Share Posted October 26, 2013 Needs a lot of cleaning and painting... 1 Quote Link to comment
ChevelleDude71 Posted November 11, 2013 Author Report Share Posted November 11, 2013 time clean/cut/weld/and paint.. Quote Link to comment
ChevelleDude71 Posted November 24, 2013 Author Report Share Posted November 24, 2013 Okay got some work done.. Here is us flipping the crossmember And the final product then I decided screw it, I'm not waiting for help, I'm putting this engine/tranny in!! I will need to raise up the front coil overs...you can really see the extra 100LBs. I also put the license plate lights on the car And installed the fuel door/lock I'm waiting for the new transmission mount to come in the mail then I will take measurements for the radiator/electric fan setup... Quote Link to comment
ChevelleDude71 Posted January 13, 2014 Author Report Share Posted January 13, 2014 Small update Got my radiator [/img] and all my windows are finally in.. [/img] [/img] Quote Link to comment
