FiveSeventyZee Posted May 31, 2012 Report Share Posted May 31, 2012 I'd venture a guess that L .490 would imply lift, but I can't figure out what the rest of the markings are. Also anyone recognize the name? First is John last I can't quite make out, anyone know? Quote Link to comment
datzenmike Posted May 31, 2012 Report Share Posted May 31, 2012 Sure it doesn't say Iskenderian ? http://iskycams.com/...d=2665&cPath=15 Import Cam DATSUN 1600cc L-16 -- 1800cc L-18 and new 2000cc L-2000 ISKY - Import Cam DATSUN 1600cc L-16 -- 1800cc L-18 and new 2000cc L-20 4 cyl. SOHC enginesGrind No (L-490) Part No. Valve Lash Caps (LC-.175) Type (Stage III) Intake (36-74) Exhaust (74-36) Lift (.490) Valve Lash Cold (.010 .012) Duration (290 deg) .050 Duratio Quote Link to comment
banzai510(hainz) Posted June 1, 2012 Report Share Posted June 1, 2012 also I dont see it pluged in the back. This cam needs Spray bar ther 490 cams usuaually dont need a spray bar but since its not plugged in the back in Needs one for sure other wise FAILURE will occur Quote Link to comment
