ftwdeathwish Posted May 28, 2012 Report Share Posted May 28, 2012 i need help im installing a sr20 in to a datsun 521 i have the motor in and i started duing the wires the tps sensor from my motor is a 3 pin and the one from the harness is 6 pin is there a way to wire it up Quote Link to comment
Josh K. Posted May 28, 2012 Report Share Posted May 28, 2012 Wrong forum to ask. Sounds like you have an auto tranny harness. http://www.plmsdevelopments.com/sr_setup_tips.shtml Quote Link to comment
philcas1987 Posted May 28, 2012 Report Share Posted May 28, 2012 all is not lost. get a pigtail of a sentra! de-pin it Quote Link to comment
ftwdeathwish Posted May 28, 2012 Author Report Share Posted May 28, 2012 sorry about posting im still new at this lol what is the wires i need to use out of the 6 pin ? Quote Link to comment
DISLEXICDIME Posted May 28, 2012 Report Share Posted May 28, 2012 google search is your friend Quote Link to comment
ggzilla Posted May 28, 2012 Report Share Posted May 28, 2012 Just get a 6-pin TPS and toss the old TPS. Quote Link to comment
ftwdeathwish Posted May 28, 2012 Author Report Share Posted May 28, 2012 yea i looked up and down on it in google no one answers the question >< im so close on my build know im stuck and might have to $$ new harness Quote Link to comment
Josh K. Posted May 28, 2012 Report Share Posted May 28, 2012 Did you look at the link I posted? Pete from PLMS knows his shit. The bigger concern should be what ecu did you get? Best make sure its a manual one. Autos : These use a different TPS. It has 6 wires. Half of it still functions the same as the manual 3 pin TPS - so all of the above still applies (wire colours are different but you still need to measure between the Black and White wires). The other half has switches (for throttle fully closed and fully open) which go to the auto trans to determine shift points. The TPS in auto vehicles is notoriously unreliable. When the auto trans half goes faulty the trans will not shift correctly. Unfortunately the main TPS part also goes bad very quickly. They suffer from moisture ingress. Once this happens a replacement TPS is required. If you've converted to a manual trans then it pays to also convert to a manual TPS for reliability's sake. They bolt up but you'll need to replace the 6 pin TPS connector and replace it with a 3 pin manual TPS connector. You only need the White (signal), Light Green/Black (5V power) and Black (return) wires. Snip the others off. Quote Link to comment
ftwdeathwish Posted May 28, 2012 Author Report Share Posted May 28, 2012 yea the ecu is a manual and so is the motor sins it has 3 pin i did go throw the link i did but corent find the part to wire up 6 to 3 Quote Link to comment
ggzilla Posted May 28, 2012 Report Share Posted May 28, 2012 You can leave it disconnected for now -- it will start and run with the factory ECU. Then later replace the TPS. Quote Link to comment
