atkinson40 Posted May 27, 2012 Report Share Posted May 27, 2012 My 620 doors don't close tight and rattle alot. Is there an adjustment procedure? The molding seems OK. Thanks Kevin Quote Link to comment
datzenmike Posted May 27, 2012 Report Share Posted May 27, 2012 The hinge pins could be worn/worn out? Do you have to lift the door slightly to close it or does the door drop slightly when you open it?? Quote Link to comment
atkinson40 Posted May 27, 2012 Author Report Share Posted May 27, 2012 There no play in the door hinges. No need to lift to close or fall when opening. Doors just don't close tight. I thought maybe there was a way to adjust the latch to get the door to close tighter. Thanks kevin Quote Link to comment
skyknight789990 Posted May 28, 2012 Report Share Posted May 28, 2012 i just did that today you have a lil play if you losen the bolts in the kick panels but if its the latch you want to adjust then you can losen it also an move it to where it feels good Quote Link to comment
