dastunboy61o Posted May 25, 2012 Report Share Posted May 25, 2012 Is it possible to use a 83-84 set up from a Nissan/Datsun years for disk brakes ?? With the brakets? For my 620 Datsun ? Quote Link to comment
Farmer Joe Posted May 25, 2012 Report Share Posted May 25, 2012 if your 620 is a 78 or 79, then yes you can swap the whole spindle over to the 620.. if its 72-77, you'll have to do the aftermarket disk brake swap.. check out the brakes forum if thats the case... Quote Link to comment
dastunboy61o Posted May 25, 2012 Author Report Share Posted May 25, 2012 Well I have a 74. I was. Trying to save the hassle from not spending a lot that's why find it all at once that's why I asked... Isn't that year a d21 hardbody. All I would need is the cailbar from it ? Quote Link to comment
jastrunk97 Posted May 25, 2012 Report Share Posted May 25, 2012 I have a 78 datsun KC so what would the difference of switching the spindles over? better breaking? less brake fade? Quote Link to comment
dastunboy61o Posted May 25, 2012 Author Report Share Posted May 25, 2012 Idk would that work ?? I want to make it all smiple then having to find different parts u kno ? As long as I have brakes with a 17inch rim I'll be happy Quote Link to comment
dastunboy61o Posted May 26, 2012 Author Report Share Posted May 26, 2012 Wudnt this be a a way to go ? Isn't this a d21 hard body? Quote Link to comment
datzenmike Posted May 26, 2012 Report Share Posted May 26, 2012 No. Later '82.5 and up 720s had similar brakes to the early D-21s. '78-'79 front disc brakes were similar to '80-'82.5 720 brakes. The 720s were getting heavier and heavier so the brakes were up-graded with larger calipers/pads and vented rotors. Quote Link to comment
dastunboy61o Posted May 26, 2012 Author Report Share Posted May 26, 2012 so this wouldnt work for general driving nothing major... would it stop a truck with 17s on it ? even if they where heavy or not ? Quote Link to comment
