Puzzling Question???
WonDereR21
So this is embarassing but I have seemed to have lost the small wire connector that goes from the gas tank to the main wiring harness to run the fuel gauge. Does ANYONE know where i could get another with a junk yard being the last resort???
  • Replies 8
Does your fuel sender have a round brass terminal, like a flat disk? If so, you can use standard female spade connector, pry it a little bit and it will slip on.
thats what I did on the KA car.
just took a reg female spade and crushed the ends a little bit so it clipped on snug.
