a2lowvw Posted May 9, 2012 Report Share Posted May 9, 2012 doing a l20b swap with a long tail 5 speed in my 521 and am looking for intake manifold. flywheel would also like a 520 metal dash cover. doesn't need to be perfect but decent is a plus i am located north of seattle Link to comment
banzai510(hainz) Posted May 9, 2012 Report Share Posted May 9, 2012 I have some L16 manifolds which you can match port. youll need to cut the crank case vent tube and splice the L16 tube on there and use a L16 PCV rubber part to the lower part of manifold.Most L 20 tubes rout to the back then coem around then hook up differently then the L16 ones which I think are cleaner set up. Hopefully you going to use a sqaure port head and keep the stock exhaust manifold.(their great) I have a 620 225mm flywheel. But youll need to use a 620 T/O bearing and sleeve . As the 521 are different. But if you can get a 200mm then u can use the 521 T/O bearing and collar. I believe Spudly with the 510 4 door had one for sale awhile back and lives up north. My L16 Intake and Flywheel are FREE long as you dont put Nascar wheels and 250PSI fuel pump , a wing ,a Jumbo Tach. a 12pound SUPER SUPER COIL on there on this 521 of yours, But OK to use a Bungy cord to hold the battery down. Im in Covington 253 653 3690 txt Link to comment
a2lowvw Posted May 9, 2012 Author Report Share Posted May 9, 2012 well i do have a small jumbo tach ;) hidden low on the steering column as it was free. i plan on running a mechanical fuel pump for the time being and will possibly update the truck to nascar status later. I do however have a stock battery hold down and prefer it to the quick change style hold downs. plans are a basic swap using what i can from the l16 that is on the truck but have the motor and trans ready so all i have to do is swap the carb on bolt up what i can for the exhaust and make it as simple of a weekend as possible... Link to comment
banzai510(hainz) Posted May 9, 2012 Report Share Posted May 9, 2012 One thing to let you know the l20 truck flywheels are 225 mm . But they are Heavy. Cars as like the 610,710and 200SX came with lighter 200mm flywheels. Its up to you it you want them. as for the trans part on 521s I dont know nothing about them using a long trans. one pc driveline? Carrier bearing? I dont think its a weekend job on this. Datzenmike would sure be the one to know or Datdoug(he knows trucks) Link to comment
a2lowvw Posted May 10, 2012 Author Report Share Posted May 10, 2012 right now i have a 1 piece driveline and a long tail 2 piece short section with the carrier bearing. from the posts i have read you have to move the carrier bearing mount back an inch and pretty much make a new cross member mount for the long tail. i have a welder and decent experience with basic fabrication. I will likely end up using a factory long tail mount and either welding a bracket together to mount to the existing cross member or building a bolt in cross member. I have some time for research before i pull anything apart... Link to comment
ggzilla Posted May 10, 2012 Report Share Posted May 10, 2012 If you put the smaller flywheel in, do you have to fit a different starter? Or does the transmission have two different places for the starter? Link to comment
banzai510(hainz) Posted May 10, 2012 Report Share Posted May 10, 2012 The Flywheels are OAD are the same. 200/225mm a2lowvw/ggzilla The guy that has the same 521 almost as yours is( hb_justice) he writes: My car hasnt lost power to the engine in a while. I have been driving with no lights on. Last night I turned them on and messed with the dash signal bulbs and got them both to light up when I have my lights on (use to be my left one lit dim only). I drove less than 5 minutes and I loss power to my engine again... I truly feel like something is going on with the dash wiring or wiring involving my headlights... Do you have any ideas? I am going crazy! anybody up north that can help him contack him. lets keep this 521 also on the roads. I would go but live in south end and work weekends right now Link to comment
ggzilla Posted May 11, 2012 Report Share Posted May 11, 2012 There's a loose connection somewhere. I could make it to Lake Stevens next week sometime. Link to comment
datzenmike Posted May 12, 2012 Report Share Posted May 12, 2012 If you put the smaller flywheel in, do you have to fit a different starter? Or does the transmission have two different places for the starter? All L flywheels are the same diameter. The size they are talking about is the clutch and PP diameters. There are 200,225 and 240mm. To use a 200mm clutch you would need a 200mm bolt pattern flywheel. Link to comment
