Jdm720 Posted September 17, 2012 Report Share Posted September 17, 2012 2eDeYe' timestamp='1347898768' post='758762']Did you have to modify the motor mounts at all? That's what I was wondering... Quote Link to comment
DREWSDIME Posted September 18, 2012 Report Share Posted September 18, 2012 X3 ........??????? Did you have to use truck oil pan and pick up? Now I see you had custom oil pan made ..pics Quote Link to comment
ratsunissan Posted September 18, 2012 Author Report Share Posted September 18, 2012 i gotta pull the oil pan off to tap it for a turbo so i will throw up some pics of that but yes custom rear sump pan and pickup. as far as the mounts go there a pain in the ass. i was told to run 1 240 mount and 1 720 mount. i couldnt get that to work so then i was told to just use my stock mounts and weld them to the frame i think thats what im going to do. my trans mount is in the mail so once that comes in i can see the angle there at and what im working with. i will post pics and keep you guys informed Quote Link to comment
ratsunissan Posted September 18, 2012 Author Report Share Posted September 18, 2012 the driverside mount looks like it will line up nice but the passangerside im a little iffy on but im gonna wait till the trans is bolted in to f with it. im either going to have to shim the mount on the frame or modify the motor mount bracket so the angles right Quote Link to comment
ratsunissan Posted September 20, 2012 Author Report Share Posted September 20, 2012 ok so i bolted up my crossmember up today and no i dont have to modify my motor mounts at all. the angles are off by probably an 1/8 to a 1/4 inch on each side so im just going to take a measurement and throw a little shim under each mount. therefore the bolts obviously dont line up so im going to weld the mounts to the frame and the shims. i had to cut my seat so that my shifter fits but no biggie heres some pics that youve all been waiting for of the motor mount angles. but to answer your question..no fabrication was necessary. besides this custom trans mount but i was told you can just run a stock one. besides that you have to drill a hole in your motor mount brackets for the stock 720 mounts to sit flush. (little tabs on the mounts) Quote Link to comment
ratsunissan Posted October 8, 2012 Author Report Share Posted October 8, 2012 . Quote Link to comment
poke_squid Posted October 9, 2012 Report Share Posted October 9, 2012 Where's the updates? Lol I'm doing the same swap I just got a 95 240 complete motor wanting to drop into my 84' 720.. I'm not going boost though.. I wanted to knw what well I need? For this swap to be completed.. I have complete motor and trans.. I knw im going to need wiring harness what harness should I use and how about my ecu? I'm a noob trying to learn lol.. if u can help I really apprciate it Quote Link to comment
poke_squid Posted October 9, 2012 Report Share Posted October 9, 2012 O yea and how about the fuel pump and fuel filter? And the front suspension?... Right now all I did to lower my truck was.. max out my torsions 3 inch drop block and minus my middle leaf spring so I'm on 2 leaf springs Quote Link to comment
ratsunissan Posted October 11, 2012 Author Report Share Posted October 11, 2012 suspension: buy some new shocks and crank down the torsion bars. look under my posts some guy explained it well fuel pump and filter not to sure..i bought a fuel cell and had a walbro 255 fp laying around but i dont think that will work with the fuel cell. get a harness and ecu out of a 95. use your stock motor mounts but your going to have to correct the angles of the mounts to frame. im still debating how i should go about this now. you can either a) cut and weld the motor mount brackets so your mounts sit flush. B) you can simply drop your motor in and shim underneath the mount and weld your mm to your frame or c) you can go the hard way and cut the mount on the frame bend it upward to fit your mm and shim the frame mount about 5 degrees Quote Link to comment
poke_squid Posted October 16, 2012 Report Share Posted October 16, 2012 Cool thanks man... would we be able to use 240 ka mm? My friend has a brand new pair that he doesn't need anymore Quote Link to comment
ratsunissan Posted October 18, 2012 Author Report Share Posted October 18, 2012 i dont think so. i bought one and mocked it up and it doesnt look like it would work. id say just stick with the stock 720 mm Quote Link to comment
ratsunissan Posted October 27, 2012 Author Report Share Posted October 27, 2012 update...frame up resto lol Quote Link to comment
71kat510 Posted October 27, 2012 Report Share Posted October 27, 2012 let me know if you need any info on a kadet setup ive done a few with lots of research Quote Link to comment
ratsunissan Posted October 29, 2012 Author Report Share Posted October 29, 2012 alright man will do thanks alot Quote Link to comment
