Phixius Posted April 22, 2012 Report Share Posted April 22, 2012 I was wondering where to get a 65-69 roadster SPL Starter. This is actually for a RB26 in my 240, and my research has found that people have been using this starter as a replacement. I have called all the parts stores and the only one that actually has it listed is Napa. Part number RAY 2444514 (standard) and RAY 444514 (premium). They do have one that’s in California; I might just get this one. But was hoping if you guys knew of a cross from another car that fits, or where have you got a starter from before? Do the 1.6 and 2.0 use a different starter or are they the same? Most the stores only listed the 2.0 and not the 1.6. :hmm: I’ve taken my starter in to all the stores for visual reference and no matches that way either. :frantics: Part numbers on the tag: 23300 20P00 S114-505 12v 1YE :sick: Quote Link to comment
datsunrides Posted April 22, 2012 Report Share Posted April 22, 2012 Most Roadster guys are going the gear reduction route using a starter from a Nissan forklift. If you want an OEM type, try one of the Roadster vendors such as Rallye or Datsunparts. Mark Quote Link to comment
MikeRL411 Posted April 22, 2012 Report Share Posted April 22, 2012 Both the 2 liter and 1.6 liter roadsters do indeed use the same starter. Unfortunately, as of 20 years ago it was NLA from Nissan. All originals were out of stock, no rebuilt units were available and none were on order. I worked through the Nissan USA parts manager and Yokohama sent me a listing of all piece parts for the starter that they still had in stock, down to the bolts for the case. I was able to order the parts I needed and rebuilt my original starter. Long story, but this starter is indeed an orphan in stock configuration. The japanese versions of the roadster can be persuaded to accept an early 510 starter since their steering column is on the right and the 510 starter will not interfer with the steering column and steering box like it would on the left hand drive versions. Quote Link to comment
Phixius Posted April 25, 2012 Author Report Share Posted April 25, 2012 Thanks for the Info guys. Well, I guess I was kind of expecting this news. Just confirming this madness. I did call al local nissan/datsun specialist (Doug @ fairlady motors or now known as UpGarage USA), and hes got those forklift starters in stock. Oh, and BTW Nissan... :fu: Quote Link to comment
