sedition88 Posted April 13, 2012 Report Share Posted April 13, 2012 So driving back from Vegas last weekend my charge light came on, found broke wire on alternator. By the time I pulled into my place I was getting a squealing noise. I replaced said alternator and drive belt, and my charge light is still on and it's still squealing when I give it any throttle. The truck fires right up, but maybe the battery still isnt completely charged idk. This is on an L18 if it matters. Any help is greatly appreciated. Thank you Quote Link to comment
moparvwfreak Posted April 13, 2012 Report Share Posted April 13, 2012 check the tension on the belt and also check to see if the water pump hasn't seized. other than that, unless you have AC or a smog pump, dunno what to say. Quote Link to comment
sedition88 Posted April 13, 2012 Author Report Share Posted April 13, 2012 Haven't had to check if the water pump is seized before. How would I go about doing it? Quote Link to comment
TENDRIL Posted April 13, 2012 Report Share Posted April 13, 2012 you turn it with belt off by hand if it dosnt move its seized, when i put a new belt on my l20 i put the tension way to tight and and made a squealed when rev'd also i had gotten a belt that was too thick or thin and it squealed right when i started it. so make sure it the right thickness and tension if so sometimes some belt dressing will do the trick -ray Quote Link to comment
sedition88 Posted April 13, 2012 Author Report Share Posted April 13, 2012 Excellent, thank you very much for the input. I'll give it a try Quote Link to comment
datzenmike Posted April 13, 2012 Report Share Posted April 13, 2012 While the belt is off grab the plastic fan blades and (gently) push one side back and the other towards the rad to see if there is any wobble in the bearing. Look up underneath the water pump. There is a small weep hole behind the pulley. If it is wet or there are signs of coolant dripping out in the past it means the seal has (or is) failing. Eventually water gets into the bearing and then it will squeal! Quote Link to comment
