konig209 Posted April 11, 2012 Report Share Posted April 11, 2012 I just rebuilt my carb on my 72 datsun but it dont seem to wanna work right at all. Here are some vids of what its doing https://www.youtube.com/watch?v=jstkV-tR9pE&feature=youtube_gdata_player Its starts right up but i dont get it https://www.youtube.com/watch?v=PGNQSyFvg1k&feature=youtube_gdata_player Quote Link to comment
konig209 Posted April 12, 2012 Author Report Share Posted April 12, 2012 What is that needle called and what is it supposed to be at? Or how many turns out? And in this pic this screw 1 the hole it goes into is stripped 2 the screw under the pump is stripped. And wasnt able to come out for the rebuild. do you guys think this carb is still good or nay? All help is greatly appreciated. Quote Link to comment
'70 521 L16 Posted April 12, 2012 Report Share Posted April 12, 2012 does it idle ok? it sounds like its stumbling when you open it up which is probably due to a lean mixture (not enough gas). look for some diagrams and find your mixture screw. just for a ballpark setting, set it to idle around 800 rpm (idle adjust screw), and turn the mixture screw out and see if that sounds any better. you want the mixture screw out just past where it starts to sound like that. this is of course the first in a long list of things that could be going on. start with this. that plunger looks like your accel pump which could also be the problem ...........getaweber...... Quote Link to comment
konig209 Posted April 12, 2012 Author Report Share Posted April 12, 2012 Thanks the accel pump gets air in it but not sure if its causing the problem. I want a weber but dont have the cash :-/ Quote Link to comment
'70 521 L16 Posted April 12, 2012 Report Share Posted April 12, 2012 try holding it down tight and revving it. that should tell you if its just because those screws are strippped out and not getting good enough suction. Quote Link to comment
Gibby Posted April 14, 2012 Report Share Posted April 14, 2012 ive been having some issues with my truck stumbling as well. carb just got rebuilt about a month ago. starts right up but when cruising it will just stumble a bit. it doesnt happen all the time. every now and then. Quote Link to comment
konig209 Posted April 14, 2012 Author Report Share Posted April 14, 2012 Well i pressed down runs a bit better going to get a small screw and nut in there to regain presure. Quote Link to comment
banzai510(hainz) Posted April 14, 2012 Report Share Posted April 14, 2012 stock carbs once bad are best to be thrown away The mixture screw with the brass tenssion spring is the mixture. I sauy turn it in all the way gently then turn it out in 1/2 increments to see what happens. More than 3 fulls turn I think somthing is wrong but try it. see what happens. Quote Link to comment
konig209 Posted April 14, 2012 Author Report Share Posted April 14, 2012 Thanks for the tip Quote Link to comment
