72 521 carb issues videos
konig209
  • Replies 8
What is that needle called and what is it supposed to be at? Or how many turns out?
And in this pic this screw
1 the hole it goes into is stripped
2 the screw under the pump is stripped.
And wasnt able to come out for the rebuild.
do you guys think this carb is still good or nay?
All help is greatly appreciated.
does it idle ok? it sounds like its stumbling when you open it up which is probably due to a lean mixture (not enough gas). look for some diagrams and find your mixture screw. just for a ballpark setting, set it to idle around 800 rpm (idle adjust screw), and turn the mixture screw out and see if that sounds any better. you want the mixture screw out just past where it starts to sound like that. this is of course the first in a long list of things that could be going on. start with this. that plunger looks like your accel pump which could also be the problem ...........getaweber......
