Doing some maintenance on the 521, need some recommendations
NSRz32
Going to replace the shocks on my truck as they're original. Rock auto has a ton of options and I'm leaning towards the KYB's as I've had good luck with them on cars. Any recommendations? The truck is lowered about 3.5 inches btw if that makes a difference
Also going to do radiator hoses and Tstat, who offers good direct fit hoses?
Thanks!
  • Replies 6
PS if buying a KYB Gas a Just) make sure to keep the plastic strap holding the shock together get evrything installed and the correct bushing. install the lower and cut the strap and have the lower bushing on the shock already. and when shock shoots out point it and guide it in the hole.
believe me its hard to compress to get it back out!!!!!!!!!
KYB GR2s are just a cheap gas shock I rate same as a Monroe/Garbrial they are not bad for 10-15$
