  • Replies 10
There are two wires entering the tank. Check that either hasn't corroded and fallen off. The yellow wire goes through the sender and out the black wire to ground. Grounding the yellow wire should send the gauge to the FULL mark.
If it does, it's possible the black wire has come loose and isn't grounding so try a good ground to the black wire to test it. If still not working then the sender inside the tank is suspect.
If it does not read FULL there is a problem between the tank and the gauge. Check the connector at the tank for corrosion.. it may not be making good contact. Under the pass side seat is a 10 pin connector where the cab and the frame harness meets. Unplug and plug several times to clean the connections.
Uh I see it's actually two black wires to the tank sender on the B-210 so unplug at the tank and run a grounded jumper wire to either of the black wires going back to the gauge end one should cause a FULL reading with the key on.
