DRIVEN Posted April 2, 2012 Report Share Posted April 2, 2012 Is your wagon green? If I say yes are the wheels for sale ^_^ ? No...it's gross mustard orange. Here: http://community.ratsun.net/topic/15889-just-another-wagon-thread/ Quote Link to comment
DRIVEN Posted April 7, 2012 Report Share Posted April 7, 2012 Something must be wrong with my computer. I can't see a single photo of your progress over the last week. Oh, wait... :sneaky: . Well...? Quote Link to comment
rat-a-dat-dat Posted April 10, 2012 Author Report Share Posted April 10, 2012 Ok. Ok… I get it more pics are needed. My goal here is to get a good running daily driver. So you won’t be seeing any major engine swaps, just boring stuff. Got the Matchbox dizzy in and wanted the box away from the exhaust manifold. The Vacuum advance can is interfering with the top hose a bit. I plan on making a spacer, 3/8” to 1/2”, to go between the thermostat housing and outlet to make it clear. Don’t have the dual choke cable yet but I got the flat tops on. After two days the front carb started blowing gas out of the overflow. The float wasn’t floating so I pulled it out and soldered it up. Hard to see in the picture but that’s a homemade heat shield made from a scrap piece of aluminum a buddy had laying around his shop. Adjusted the valve lash and changed the belt. Now that the car has some power back the clutch is slipping so that is next up. That and figuring out what is going on with the heater control valve. It stopped moving and I see a bit of seep going on down there… better get to it before it gets bad. Quote Link to comment
rat-a-dat-dat Posted April 10, 2012 Author Report Share Posted April 10, 2012 It is comming off soon, I will take pictures before it does. ohh yeah removed the tow package too! B) It was bolted into the outer most bumper mounts 2x on both sides. And one in the middle of the sheet metal just to make sure it wrecked everything if it did come loose! It has a new home in the weeds outside my garage. Quote Link to comment
DRIVEN Posted April 10, 2012 Report Share Posted April 10, 2012 There's at least 2 heater valve repair write-ups in the How-To section. I seem to remember a mklotz70 write-up in one of his threads too. That hitch is a confusing combination of hilarious and frightening. Quote Link to comment
rat-a-dat-dat Posted April 11, 2012 Author Report Share Posted April 11, 2012 There's at least 2 heater valve repair write-ups in the How-To section. I seem to remember a mklotz70 write-up in one of his threads too. That hitch is a confusing combination of hilarious and frightening. Found the heater fix posts. And yes that thing is scary! I thought about putting it up for sale before I came to my senses. Quote Link to comment
rat-a-dat-dat Posted April 17, 2012 Author Report Share Posted April 17, 2012 Had to get the exhaust patched up after the rotten hangers let loose. Got it wired up until I can get new hangers. Quote Link to comment
bananahamuck Posted April 17, 2012 Report Share Posted April 17, 2012 I think this car deserves to only have slight mods done to it..Boring up dates, , or not she`s a beauty and i will keep checking in on it.. :thumbup: Quote Link to comment
rat-a-dat-dat Posted April 24, 2012 Author Report Share Posted April 24, 2012 Pulled all of the front suspension off. Cleaning everything up and painting it. New struts are here and bushings on the way. Quote Link to comment
DRIVEN Posted April 24, 2012 Report Share Posted April 24, 2012 Anything special in the works or going back together all stock? Quote Link to comment
rat-a-dat-dat Posted April 25, 2012 Author Report Share Posted April 25, 2012 Anything special in the works or going back together all stock? I was going to lower the spring pearches with collars but... I picked up a package deal. New set of ground control coilovers for the front, some stiffer springs for the rear, and rear disk brake conversion. So the new plan is bushings, coilovers, strut inserts, and clean up and paint. Move on to the rear and do the same minus coilovers. oics to follow. :) Quote Link to comment
DRIVEN Posted April 25, 2012 Report Share Posted April 25, 2012 Approved. You may continue. Quote Link to comment
rat-a-dat-dat Posted April 27, 2012 Author Report Share Posted April 27, 2012 New strut(MR2) Vs. old strut. MR2 strut won't fit in the hole. Took care of that problem. Could have used a file but this was more fun. B) cut the lower spring perches off. Ohh and a pic of the new hardware. Test fit everything last night but that's as far as I have gotten this week. Bushings should be here tomorrow Quote Link to comment
rat-a-dat-dat Posted April 28, 2012 Author Report Share Posted April 28, 2012 Poly bushings are here! Quote Link to comment
rat-a-dat-dat Posted April 28, 2012 Author Report Share Posted April 28, 2012 Little cleaning before pressing out the bushings. and a litte cutting to fit the shorter strut inserts. Thats it for now. Heading over to use a friend for his press. err use a friends press. ;) Quote Link to comment
rat-a-dat-dat Posted April 28, 2012 Author Report Share Posted April 28, 2012 Even with a press getting those LCA bushings is a bitch! At first I was trying to push the whole thing out and it wasn't budging so I took out the tube out of the center and the rest came pretty clean. That was the first one... taking what I learned from the first one I pushed the center out and started on the rubber. Got it loaded up with plenty of presure and it wasnt moving so I flipped it over and pushed it the other way. It went but things kind got sideways on me and it busted part of the sleave that I didn't think was a sleave. From what I had read on other posts here the 69s didn't have sleaves but I'm glad they do cause when I got it pressed out the energy bushing fit perfect. So back to the first one to press out the sleave and holy shit it ain't going nowhere. Monkeyed with it going back and forth pressing on in and it finally busted loose. It was loud! It is going to be OK to run without the sleaves? From the size of the bushing it seems like they are made to run without. Quote Link to comment
bananahamuck Posted April 28, 2012 Report Share Posted April 28, 2012 your new bushing dont have the outer metal tube .? are they aftermarket type 2 piece poly.? if they are and they fit tight with that tube removed then ,,,,there you go. maybe. Quote Link to comment
rat-a-dat-dat Posted April 29, 2012 Author Report Share Posted April 29, 2012 your new bushing dont have the outer metal tube .? are they aftermarket type 2 piece poly.? if they are and they fit tight with that tube removed then ,,,,there you go. maybe. Yep. Two piece no outer metal shell. Quote Link to comment
rat-a-dat-dat Posted May 1, 2012 Author Report Share Posted May 1, 2012 Welded the strut tubes yesterday. Did a little work with the grinder today and painted them. Just waiting for the paint to dry. Quote Link to comment
Laecaon Posted May 1, 2012 Report Share Posted May 1, 2012 Yay watching paint dry, my favorite pastime. Quote Link to comment
rat-a-dat-dat Posted May 6, 2012 Author Report Share Posted May 6, 2012 Here she is all put back together. Lower than I thought but I'm loving it. 3 Quote Link to comment
rat-a-dat-dat Posted May 6, 2012 Author Report Share Posted May 6, 2012 510 slot car my Uncle gave me. Quote Link to comment
Laecaon Posted May 6, 2012 Report Share Posted May 6, 2012 That is awesome looking! Good job! Quote Link to comment
rat-a-dat-dat Posted May 6, 2012 Author Report Share Posted May 6, 2012 That is awesome looking! Good job! Perfect! Thanks! :) Quote Link to comment
