datsun77 Posted April 28, 2008 Report Share Posted April 28, 2008 i have searched the forums on this subject but there are several different combinations on the wiring out there my truck is a 1977 620 and i am going to use a alternator off a 80 720 does anyone know the correct full proof wiring for this truck thanks! Quote Link to comment
fiveNdime Posted April 28, 2008 Report Share Posted April 28, 2008 Why are you going to that one? you could wire in a GM 1 wire?? I don't know the answer to your question buy the way:confused: The 80 720 alternator is internally regulated and the 77 620 isn't, I do know that! Quote Link to comment
datsun77 Posted April 28, 2008 Author Report Share Posted April 28, 2008 how does the wiring on the gm work.what year model are you using the reason i wanted to use the 720 is because i got it for free but im open to other ideas thanks! Quote Link to comment
banzai510(hainz) Posted April 29, 2008 Report Share Posted April 29, 2008 this is for a late model 510 but the color codes are the same I believe on the truck http://datsun510.com/photopost/showphoto.php?photo=124&size=big&papass=&sort=1 just jumper the wires at the volt reg end by making jumpers and then inserting them in the connector,so you can go back to stock. One think to know is on the trucks the steering idler arm pivot may get in the way due to the bigger alternato and its more than just a install. I think most 620 alternator were the smaller 35 amp units. a bigger one you might not be able to get the belt tight enough w/o hitting the idler arm. I had to grind mine on my 521 when installing a 50amper. Nothing is totally FREE!!!!!!!!! might be Ezer to get the correct alternator for now PM Jester on here I think he recent did something like this. Quote Link to comment
datzenmike Posted April 29, 2008 Report Share Posted April 29, 2008 This is not the best way to do this but it does work.The 720 alternator mount to the block (three bolt) is positioned higher than the 620. (at least it is on the Z motors) You might look at swapping it too. I did this swap a long time ago and swapped the mount and used a 280 Z lower rad inlet to the block because it is swept back more and gives better clearance. I had to slip the new belt on the pulley first, then tighten the alt. bolts to get tight without hitting the idler grease nipple. Maybe take the nipple out and put a plug in? Quote Link to comment
LCDC Posted April 4, 2009 Report Share Posted April 4, 2009 Anyone got a picture of this VR jump plug bypass to use an IR alternator? Quote Link to comment
banzai510(hainz) Posted April 4, 2009 Report Share Posted April 4, 2009 use the coclor code on the wire harness as some aftermarket Volt regs the color codes are misalighed. use the old volt reg connetor to make jumper,( i would not myself .Wky break a good volt reg if still good) can make your own jumpers Quote Link to comment
