My 1967 520 project
I bought this for 500 dollars and drove off with it.Now my good buddy sick620 is helping me out with the rebuild of the project and I am thankful.The wiring has been a bit of a Rats nest...we also have to replace the the entire radiator system because the last owner installed it like it was legos,just pieced it together.If sick620 wouldn't have played rescue ranger my datsun would have just been driven off the cliffs at the cascade mountains.
l16 swap
dogleg 5speed
weber
western wheels
metal dash
petronix electro dist.
  • Replies 13
Truck was a j13 originally.. p/o installed l16... alternator died because they were using the original and they had cut it open and ghetto rigged it to make it charge... the battery was mounted under the bed... cut out the battery and installed a new remanned alt.. we had to get a smaller belt and make a smaller bracket because there wasnt enough room for our alternator. We went through the wiring and cleaned it up. the radiator dosnt have a cap on top and is rigged up to a ghetto vw overflow. I want to get a better radiator... the fuel pump is a electric one and I would like to switch back to the original manual style... we got everything back together but now truck wont start, we need to check our wiring again in the morning...
hey when we going to finish it and start it... also im getting my truck done metallic green for $450 :)
That's incredible... B)
l16 swap
dogleg 5speed
weber
western wheels
metal dash
l16 swap
dogleg 5speed
weber
western wheels
metal dash
HEY CANT GO WRONG WITH SOME NEW CASTLES IT WAS FREEZING OUTSIDE SO IT KEPT EM COOOOOOOOOOOOOOOOOOOOOOOOOLD AS ICE
