Dantheman Posted March 22, 2012 Report Share Posted March 22, 2012 Please forgive my lack of knowledge as this subject has been covered at length. But I tried a google search on "strut part# 734632" and the only thing coming up is Gabliel out of South Africa. The inserts are stamped "Made in USA". Thanks for any help. Quote Link to comment
Dantheman Posted March 23, 2012 Author Report Share Posted March 23, 2012 As I am reading more, Every ones inserts body lengths are much shorter than mine. The body is 16 3/4". Quote Link to comment
datzenmike Posted March 23, 2012 Report Share Posted March 23, 2012 Assume this is for the 70 goon in your profile? Too bad the valve body was taken out and replaced with an insert or you could have just replaced the oil. Quote Link to comment
Dantheman Posted March 24, 2012 Author Report Share Posted March 24, 2012 I wish I had them also, but it sounds that if I lower the car much with that tall of a strut, it won't leave much in suspension travel. I learned a lot speaking with Jay at Ground Control today, and he said he guessed I would be wanting a shorter strut body in the near future. For the reason explained above and now would be a good time to do it. Any recommendations on inserts. From what I have read, it seems that the Tokico blues are popular. Quote Link to comment
datzenmike Posted March 24, 2012 Report Share Posted March 24, 2012 You will need to shorten the strut tube to take any advantage of a shorter cartridge. Are your's stock '70 struts? Quote Link to comment
Dantheman Posted March 24, 2012 Author Report Share Posted March 24, 2012 I have miss written the year of the wagon. Opps. It's a 71. I think I was told in 1969 the strut body size was changed. The guy at Ground Control said that the wagons had taller struts than sedans. At least that Is how I understood him. Quote Link to comment
TENDRIL Posted June 14, 2012 Report Share Posted June 14, 2012 yea if your strut tube is stock your going to have a hard time finding any inserts, unless you have a ridiculous amount of spacers Quote Link to comment
ggzilla Posted June 14, 2012 Report Share Posted June 14, 2012 You can fit shorter inserts in stock un-cut struts. Just use spacers. It's not rediculous at all. Or just buy new insert cartridges for stock Datsun 510. Google this: datsun 510 strut insert cartridges I see Monroe and Koni for sale. Quote Link to comment
hobbes_the_cat Posted June 15, 2012 Report Share Posted June 15, 2012 Or swap to 280zx strut assemblies. The are shorter and the bonus is bigger brakes! They could also be shortened if you want to go even lower, then you could use mr2 inserts or rabbit inserts. Quote Link to comment
TENDRIL Posted June 15, 2012 Report Share Posted June 15, 2012 1982 nissan maxima cartridge from rock auto, is what im going to try all the specs. Seem to match up to what i need but the P.O. of my goon shortened the tubes an inch or so to 15in so they should fight snugly! Quote Link to comment
