my 720 5.0 turbo
stupit racing
project update
so the truck ran a 10.2 at 132mph at 12 psi on pump gas and a little traction issue, and ended up hurting the motor, the blocked cracked right down the middle, not bad for a motor that i'd race for 8 years
so i pickd up a new block and got some new parts
pulling the old motor
new afr cylinder heads, arp bolts
probe srs light wieght forged piston and mahle racing rings
flat top with 58cc heads and the block milled to 0, should bring the compression to 10 to 1
got the rotating assembly balanced and assembled the new motor
the new heart
  • Replies 38
yes its still gonna be turbo, gonna try high compression low boost and thanks
the five lug conversion, toyota hubs with my stock spindle machined
more pics
motor install
drove it on the freeway and the motor got really hot due to the higher compresion
so i relocated the radiator back to the front
what a tight fit
and with the radiator and electric fan up front i had to find a place for the intercooler
  • 5 months later...
here's some update
bought a new turbo, the turbonetics hurricane benita bb
new and old turbo
relocated the traction bars and mounted cc drag shocks
got some weld pro stars
here's a video of the first time out with the new set up. 10.65 @ 129mph and still on pump gas
still tuning, had to back off timing and slowly get on it  due to no traction and tires being too small
so i got rid off the 26x8 slicks and got 28x10.5 slicks
now i'm just waiting for a nice sunny day to test and tune :geek:
