Misfire question
deejay
I have a 1970 l16
When I start it up in the morning or after sitting for awhile it starts up rough
Like misfiring on # 2 cylinder
I have a new electronic ing. ( took the points out )
New plugs wires and cap and roter
Checked the compression and across all calendars there all about even with in
2-5 psi of each other
After it warms up usually does better gets about 27mpg
Little sputter here and there
Also has a webber carb
Any ideas what could cause this
  • Replies 11
Is it new or used? Do you have any idea what this mystery weber was off of? Used, it could be full of someone else's problems like missing or mixed up parts. It could be jetted for a much larger motor.
Ya. Pulled # 2 plug wire no change also changed plugs and wires and if I pull any other plug with # 2 plugged in its a big change compared just pulling # two
The carb is tuned in just pump gas a few times pull choke a little and drive and usually half mile down the road u can just push the choke in and go even when show is on the ground ez starts I'll be checking the valves this week
If the compression is the same as the other cylinders then it should fire just like the other cylinders. If you pull the plug wire off and not much change then the spark is going somewhere else. Try swapping the #2 wire to another cylinder and see if the problem moves. If it does the wire is bad. Try swapping the plug to another cylinder and see if the problem moves. If it stays the same put a new dizzy cap and rotor on it.
