Dogleg weakness?
EricJB
  • Replies 29
The L16 flywheel won't fit the L20B.
In order to use the L16 clutch & pressure plate you will need a 200mm L20B flywheel from a car motor.
Truck flywheels are 225mm so if the '80 motor has a flywheel and pressure plate on it you can use it if you go back and grab the release bearing collar that's on the '80 clutch arm.
I would but the truck didn't have a transmission in it anymore, i guess ill have to buy a new one.
thanks a lot Datzenmike.
I do have the flywheel from the truck (6 bolt), I'm going to buy the truck clutch kit instead.
Make damn sure you get a proper release bearing collar for the 225mm. The one on the L16 200mm won't work on a 225mm clutch.
If you are absolutely sure it's an '80 720 2wd then the correct collar is Nissan # 30502-21001 about $35 but you can use this number to reference one from NAPA or Autozone... w/e.
