sjdon67 Posted March 13, 2012 Report Share Posted March 13, 2012 Has anyone used this? I have a 77 B210 Im thinking about using it in. Would it work? http://www.ebay.com/itm/Electronic-Ignition-Conversion-Kit-1966-80-Datsun-Nissan-4-cylinder-Hitachi-/310382045099?fits=Year:1977|Model:B210&hash=item48443627ab&item=310382045099&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr Quote Link to comment
kneesamo Posted March 13, 2012 Report Share Posted March 13, 2012 I might just spend a little more and get a petronix. Quote Link to comment
banzai510(hainz) Posted March 13, 2012 Report Share Posted March 13, 2012 Hotspark is made in china But the Orginal Pertronix is made in the USA. look under Vintage Performance and they have a listing. about 80$ I guess you would have a single point distributor correct? You use the stock coil and ballast,thats it. dont put a low ohm coil in there. Quote Link to comment
sjdon67 Posted March 13, 2012 Author Report Share Posted March 13, 2012 Yes I have a single point distributor, Made is USA is always good. Are they easy to hook up? Quote Link to comment
datzenmike Posted March 13, 2012 Report Share Posted March 13, 2012 I might just spend a little more and get a petronix. Or the same (probably less at a wrecker) and get a proper matchbox EI ignition and coil from a '79 and up 210 A series motor or a 310 A series up to '81. Forget that Chinese crap. Quote Link to comment
banzai510(hainz) Posted March 13, 2012 Report Share Posted March 13, 2012 Yes Very EZ,At lest to me or find a later 210 EI one as Datzenmike suggested and let soem know on here and you can make it work with your point coil and ballast(hook up like a Pertronix) or use a Ei coil and remove the ballast resisitor. Quote Link to comment
