edakotaford Posted April 25, 2008 Report Share Posted April 25, 2008 before i got it, it was in a front end Tbone accident. everything physically LOOKS fine now, but left member[section that fender sit on/wheelwell] is pushed in about an inch. car pulls a bit to the left. no real problems with it, but i want it back to par. what should i do? Quote Link to comment
gen4maxima536 Posted April 25, 2008 Report Share Posted April 25, 2008 probably have to take it to a body/frame shop and have them straighten it. Quote Link to comment
pope_face Posted April 25, 2008 Report Share Posted April 25, 2008 ^ What he said. If you're not too pressed to keep the 510 on the road you could pull off the wheel and take a close look at the body/suspension/steering, and maybe fix it yourself. If it's just a bent steering/suspension part, then replace it with one from a dismantlers or a parts shop. If it's the body itself, then you may be able to use a BFH to whack in back in line. If you need it done pronto, then a professional shop would be your best bet. Even if you do it yourself, you should probably take it in for a check and alignment afterwards. Quote Link to comment
