reese Posted April 23, 2008 Report Share Posted April 23, 2008 I am doing a head gasket on my L18 soon, should I put new head bolts in as well? Quote Link to comment
pl521sss Posted April 23, 2008 Report Share Posted April 23, 2008 If you do get them new. Consider using the 280zx turbo head bolts. http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Code=P7600-KIT I think the reason for this is higher Tensil strength. Quote Link to comment
moparvwfreak Posted April 23, 2008 Report Share Posted April 23, 2008 if ya can do it right. ARP head studs. if they are available. i dont see why they wouldn't be. Quote Link to comment
ggzilla Posted April 23, 2008 Report Share Posted April 23, 2008 New head bolts are not needed. Unlike some newer engines with one-time-use bolts, the Datsun head bolts are the good old-fashioned reusable kind. Just clean the bolt and bolt hole, use a torque wrench, tighten in three steps using the circular pattern. Good to go... Quote Link to comment
datsunon40s Posted April 23, 2008 Report Share Posted April 23, 2008 I used the same headbolts for 8 different motors in highschool I had a very freeflowing head with a huge cam and kept over-revving it :P rods went-a-flyin:D and never had a head gasket or head warpage issue Quote Link to comment
