edakotaford Posted April 23, 2008 Report Share Posted April 23, 2008 so i am supposed to be picking up an L20b for my dime in about two weeks. i've heard a lot about swapping L16 heads onto them for better highend power. not sure exactly though the specs of the modifications, or the engine when it's done. any modifications in mounting or timing of the engine i'll need to do? Quote Link to comment
gen4maxima536 Posted April 23, 2008 Report Share Posted April 23, 2008 as far as changes in mounting or the timing, it would be exactly the same, but before you do it, some L20B heads should flow better than a 210 head, like the U67. info: http://www.the620.com/html/tech/head_ID_2.htm Quote Link to comment
fivetengarage Posted April 23, 2008 Report Share Posted April 23, 2008 Make sure you get the flywheel.The L16 has 5 mounting holes.L20 has 6. Quote Link to comment
datsunon40s Posted April 23, 2008 Report Share Posted April 23, 2008 L16 heads have smaller combustion chambers for more compression but also smaller valves so you have to weigh the pros and cons Quote Link to comment
