Datman74 Posted February 21, 2012 Report Posted February 21, 2012 Just picked up a set of 14 x 6 +10 jellybean alloys for the 411 but looking at them I'm not sure that they are going to fit. I think they were originally off a 240K. I still need to pick up some longer shank lug nuts to fit them but was wondering if anyone knows if this size wheel will fit? Any suggestions on what size tyres to run on them if they do? Thanks guys, any advice is appreciated Chris Quote
erichwaslike Posted February 22, 2012 Report Posted February 22, 2012 I know a 14x7 0 offset will fit with rolled fenders Quote
ggzilla Posted February 22, 2012 Report Posted February 22, 2012 The wheels will fit. But will the tires that you put on them? Like erich says, less positive offset will stick out past the fender. Stock offset was probably +25. But if they hit on the inside, you can always use 10mm spacers with those wheels to tuck them back out. Or use narrow 165 or 175 tires. Quote
erichwaslike Posted February 22, 2012 Report Posted February 22, 2012 im looking to run a 13x7 up front and a 13x8 in the rear. ill be running a 175/50r13 if i can find em. other wise it will be a 155/80r13. im guessing the rear will be tight but i think it will make it Quote
Datman74 Posted February 22, 2012 Author Report Posted February 22, 2012 What kind of offset would you be looking at for the front, I just test fit the +10 and it looks like its going to pop out too far past the fender. Guy a the local tyre place reckons +25 would be better....starting to get confused on this one Quote
ggzilla Posted February 23, 2012 Report Posted February 23, 2012 Confused? Sounds right to me. More positive offset shifts the wheel towards center of car. Less positive offset shifts it outside. The stock offset usually centers it inside the wheelwell, allowing the widest tire possible. Guys that fit +10 or Zero offset like it because it has "more dish", but it makes the tires stick out of the fenders. Quote
Datman74 Posted February 23, 2012 Author Report Posted February 23, 2012 That makes sense, thanks ggzilla.... The more I look at this I think I might keep these wheels for the 510 and try and get something that sits more flush with the fender for the 411. 14 x 6 with +0 might be easier to get passed for a roadworthy certificate over here. I think they will knock back anything with the tyre outside the fender In another part of my brain I'm thinking about steelies. Any steelies you guys can recommend that and 4 inches wide? seen a few powdercoated and they look the business Quote
MikeRL411 Posted February 23, 2012 Report Posted February 23, 2012 That makes sense, thanks ggzilla.... The more I look at this I think I might keep these wheels for the 510 and try and get something that sits more flush with the fender for the 411. 14 x 6 with +0 might be easier to get passed for a roadworthy certificate over here. I think they will knock back anything with the tyre outside the fender In another part of my brain I'm thinking about steelies. Any steelies you guys can recommend that and 4 inches wide? seen a few powdercoated and they look the business The original 411 tyres were 13 x 5 inch, same as the old 1500 cc 310 roadster. Later 311 series [1600c and 2000cc] roadsters upped the diameter to 14 inches. If you can find a set of 14 inch roadster wheels and hub caps I think you would like them on your 411. Quote
Datman74 Posted February 24, 2012 Author Report Posted February 24, 2012 Hmmm, sounds like that's what I'm after Mike. The 411 I have is sitting on 13 x 4s and the 410 seems to be wider so I'm assuming it;s on 13 x 5s. Seeing as I will likely be poaching parts from the 410 for the 411 I might swap the wheels over and see how it looks. In the meantime I will do some digging and see if anyone in the Roadster club has a set of the 14s laying around... Thanks for the info and patience guys, I'm on the learning curve now, shouldn't be long before I know a little bit more about what I'm talking about Quote
Datman74 Posted February 24, 2012 Author Report Posted February 24, 2012 Found these lurking around the garage. from what I can tell only one of these is an original 411 and the smaller center cap kind of looks like a roadster type.....trouble is I only have 2....the pic below is against the wheels I have on the 410 at the moment. They measure 14 inches which surprised the heck out of me .... might get lucky here and not need to chase anything other than a couple of center caps Quote
MikeRL411 Posted February 24, 2012 Report Posted February 24, 2012 Found these lurking around the garage. from what I can tell only one of these is an original 411 and the smaller center cap kind of looks like a roadster type.....trouble is I only have 2....the pic below is against the wheels I have on the 410 at the moment. They measure 14 inches which surprised the heck out of me .... might get lucky here and not need to chase anything other than a couple of center caps The left hub cap is the Roadster type. The right wheel cover is the standard 13 inch circumferential slotted P411 and PL411 cover, the 13 inch full wheel cover 1500 roadster and 411 Super Sport Sedan type was optional at the dealer in the USA on the PL version, the RL version came with the "port holes" as standard, don't know what options were available in Oz. The 411 wheels came with the clips for the small hub caps regardless of which wheel cover or hub cap the car came with. Quote
OzDat Posted February 25, 2012 Report Posted February 25, 2012 I have some of the small caps you can have for shipping cost. PM me (I'm in Queensland) Quote
Datman74 Posted February 25, 2012 Author Report Posted February 25, 2012 Mike, you are a wealth of knowledge, thanks for taking the time to reply. Looks like all of the wheel have the clips so I'm assuming they are original 14inch 411s Cheers Greg, you have a PM, hope there is some way I can help out in return Chris Quote
erichwaslike Posted February 25, 2012 Report Posted February 25, 2012 I have some of the small caps you can have for shipping cost. PM me (I'm in Queensland) is this greg that has the all yellow 411 with no bumpers on it? Quote
OzDat Posted March 2, 2012 Report Posted March 2, 2012 is this greg that has the all yellow 411 with no bumpers on it? Sure is. Quote
erichwaslike Posted March 3, 2012 Report Posted March 3, 2012 ur car is awesome man. i see pics of it all over the internet. Quote
OzDat Posted March 3, 2012 Report Posted March 3, 2012 ur car is awesome man. i see pics of it all over the internet. Thanks for that. She is a lot of fun and gets around a bit. Quote
