lower thermostat housing
  • Replies 2
The thermostat housing for the 510 ranges from $15 (pre '70 the one you want?) to about $38 at dealer. The L series housings vary by the number of senders and vacuum switches used in addition to the water temp sender. Some even have a 3 bolt water outlet cover over the thermostat. All would do the same job as long as the extra holes are filled or have the senders in them.
Use Teflon tape or anti seize compound on the new one.
