pl624de Posted January 26, 2012 Report Share Posted January 26, 2012 I have a 1974 Datsun pl620 with a 1993 ka24de engine and trans running a 1995 ecu and engine harness along with s14 distributor and MAF. I am trying to wire it up to run from the F11 connector as I have heard done many times before but have had no luck as of yet. I have my in tank electric fuel pump wired on a relay with key on I have my cooling fans on a thermostat and relay with key on I also have my starter wired through the ignition switch to elliminate the s14 lower harness. I know basic swap wiring but I am very new to nissan/datsun stuff and would appreciate any help. Thank You I PLAN ON DOING THIS WITHOUT THE PRE-WIRED RELAY BOXES I SEE ON THE SITE Quote Link to comment
Digi7al Trauma Posted January 26, 2012 Report Share Posted January 26, 2012 I PLAN ON DOING THIS WITHOUT THE PRE-WIRED RELAY BOXES I SEE ON THE SITE why dont you find out how/what is in it... im pretty sure (icehouse?) would have no issues breaking it down........ also.... trying to figure out what your actual issue is..... what type of "1995 ecu"? is it a 240sx? altima? bluebird? largo/caravan? .... you mentioned the f11... i dont know the issues your having with it, but it connect to the "e208" plug on the eng. lower harness... (for the o2 sensor &Crank positioning sensor) Quote Link to comment
pl624de Posted January 26, 2012 Author Report Share Posted January 26, 2012 I am a big fan of the relay box they build and think its perfect for someone who hasn't wired a fuel pump off of key on and its own relay and since my 95' harness has a connector for the eccs relay it almost makes the $150 box useless to me but it's perfect for MOST ka24 swaps. I know that all I need is switched 12v, constant 12v, ground and start signal witch is the same as starter motor cranking (if I'm right)??? I have a Mail Relay and Fuse Box already wired and just need someone to point me in the right direction as far as what wires on the F11 connector get tapped. Quote Link to comment
pl624de Posted January 26, 2012 Author Report Share Posted January 26, 2012 Sorry it's the F3 connector by the ecu plug and it's a 1995 240sx 5sp non abs. Thank You for your help Quote Link to comment
Digi7al Trauma Posted January 26, 2012 Report Share Posted January 26, 2012 Sorry it's the F3 connector by the ecu plug and it's a 1995 240sx 5sp non abs. Thank You for your help ah, gotcha! the F3 connects to the M63 plug on the dash harness... mostly its for the instrument cluster Quote Link to comment
pl624de Posted January 26, 2012 Author Report Share Posted January 26, 2012 So how do you power up the ecu then? I had someone tell me it was through that connector (F3)? Quote Link to comment
Digi7al Trauma Posted January 26, 2012 Report Share Posted January 26, 2012 So how do you power up the ecu then? I had someone tell me it was through that connector (F3)? ...the black/white wire should be the +12v constant for the ecu.... cant remember what plug tho..... still looking for the 12 switched you need.... im alil thrown off by the lack of the lower harness lol Quote Link to comment
DAT510 Posted January 26, 2012 Report Share Posted January 26, 2012 Where are you in CA? Quote Link to comment
pl624de Posted January 26, 2012 Author Report Share Posted January 26, 2012 San Jose, ca Quote Link to comment
DAT510 Posted January 26, 2012 Report Share Posted January 26, 2012 San Jose, ca There is someone in Tracy i know that has done these swaps, his name on here is Datsloco. i myself don't know much, but he should be able to help if you want someone local. there are plenty of people on this forum as well that would love to help. Quote Link to comment
Creepy Cruiser Posted January 26, 2012 Report Share Posted January 26, 2012 I do all mine (for the s14) off the long white plug, (F3 connector) like you mentioned. I use these two diagrams if I'm not using the Can/Am box. Quote Link to comment
pl624de Posted January 26, 2012 Author Report Share Posted January 26, 2012 thanks, will give it a try today? Quote Link to comment
bluebird4200 Posted August 16, 2013 Report Share Posted August 16, 2013 Who has pre wiring for me to get my Ka swap in to my 1974 Datsun 620? I have an s14 ka engine. Any way to make it easier for me is good to go! Quote Link to comment
