Jan_280Z Posted January 20, 2012 Report Share Posted January 20, 2012 Hey guys, So I managed to break THE longest waterpump bolt in my brother's truck when I was replacing the waterpump. As a result I'm not disassembling the whole front to hopefully drill/tap the hole. Here's the question, how exactly do I remove the oil pan? Do I remove the front cross member or do I just lift the motor up or something? Any help would be greatly appreciated at this time. Jan Quote Link to comment
datzenmike Posted January 20, 2012 Report Share Posted January 20, 2012 On the 620 the cross brace can be unbolted and with some prying, removed. Now you should be able to gat at the oil pan. If this is to get the timing cover off, most people just loosen the bolts at the font and a few down the side and gently pry the pan down so the timing cover can slide forward and out. Nothing wrong with taking the whole pan out so you can replace the gasket with a nice new one. Quote Link to comment
Jan_280Z Posted January 20, 2012 Author Report Share Posted January 20, 2012 To make sure, the cross brace is the large metal piece under the oil pan near the torsion bars correct? The pan has a leak in the gasket so I might as well get that while I'm taking the engine apart. On a side note, will a Z waterpump work on a 620? Quote Link to comment
datzenmike Posted January 20, 2012 Report Share Posted January 20, 2012 A quick look says probably not. I think the crank pulley Vs are located differently so the water pump pulley is also different, not sure but something is different about the L6 motors. Quote Link to comment
Jan_280Z Posted January 20, 2012 Author Report Share Posted January 20, 2012 Ok cool thanks. I'll let you guys know how it all went Quote Link to comment
mike Posted January 24, 2012 Report Share Posted January 24, 2012 For removing your oil pan, do what Datzenmike sid and youre also goin to have to remove the pitman arm from the passenger side frame rail. You can push the steering linkage out of the way and the pan just drops out. Shouldnt be too tough but make sure that you keep the pan bolts in order especially on the front timing cover area. Ive had to replace a broken timing cover because the PO put too long of bolts in and broke the cover when overtightening. Quote Link to comment
darrel Posted December 5, 2012 Report Share Posted December 5, 2012 You didn't tell us how it went. Quote Link to comment
