Yooperdatsun Posted January 12, 2012 Report Share Posted January 12, 2012 Picked up the datsun. took her on the maiden journey of 500 miles. first 350 went reasonably well besides the tranny didn't want to come out of 5th very easy. and then she just went into "nuetral" while cruisin at about 55 or so. still in 5th gear but no engagement. the weird thing is that it didn't "pop" out of gear. like a false nuetral on a motorcycle when the shifter forks get bent. but I couldn't even pull the shifter back into nuetral. had to really reef on the handle to getter back. finished the ride in 4th gear. been searchin here and google all night and can't find anything. any thoughts? seeing this is a sub 1000 dollar truck I'm not gonna dump too much money. most drives she goes on will be sub 60mph so worst case scenario just get some bigger rear tires. haha. pics up tomorrow. thanks. Quote Link to comment
ggzilla Posted January 12, 2012 Report Share Posted January 12, 2012 What kind of truck is it? If it has an L16, it can do 70 mph with only 4th gear. Just let it rev. Speed limits were 75 mph back in 1969. Quote Link to comment
albyneau Posted January 12, 2012 Report Share Posted January 12, 2012 What kind of truck is it? If it has an L16, it can do 70 mph with only 4th gear. Just let it rev. Speed limits were 75 mph back in 1969. Mine had an exhaust leak~ and above 60 it sounded like I should file a flight plan w/ NASA.... Quote Link to comment
Yooperdatsun Posted January 12, 2012 Author Report Share Posted January 12, 2012 sorry guys.... its a 78 620 with a 5 speed. x18k miles on the odo... most likely 118k. did some research and apparently the 4 speeds 4th rear ratio is 1 to 1 and the 5 speeds 4th gear ratio is the same... so unless its an easy fix or I can find a good used 5 speed I'm thinking its not gonna be worth it. I do remember reading that u need to watch play in the drive shaft???????? Quote Link to comment
KC Phirus Posted January 12, 2012 Report Share Posted January 12, 2012 Where are you? That's the difference between another tranny being worth it or not. Have you tried changing the grease? Could be a bent fork but all gears would be difficult. Quote Link to comment
datzenmike Posted January 12, 2012 Report Share Posted January 12, 2012 You now basically have a 4 speed so just drive it. Reverse is on the same fork so if it's working I doubt it's the fork. There are three forks and shift rods. 1/2, 3/4, and 5/Rev. Quote Link to comment
KC Phirus Posted January 12, 2012 Report Share Posted January 12, 2012 You now basically have a 4 speed so just drive it. This^ You can do highway speeds in fourth no prob. When it starts to sound like a zero fighter then you're halfway to redline. Quote Link to comment
Yooperdatsun Posted January 12, 2012 Author Report Share Posted January 12, 2012 in western north dakota... oil field. grease? I think it may be time for a manual.. hahaha. at this point I'm gonna look over stuff and make sure theres oil in the tranny ect ect. frikkin COLD today. old man winter has returned. preventativecar maintenance measures just went to zero. haha Quote Link to comment
KC Phirus Posted January 12, 2012 Report Share Posted January 12, 2012 Pull the plug out of the bottom of the trans. Don't be surprised if nothing runs out. I'm not sure what's recommended but I used 80w. Quote Link to comment
ggzilla Posted January 12, 2012 Report Share Posted January 12, 2012 Use GL-4 (not GL-5) 80W-90. Don't use 90 in areas that go below freezing. 80W only good for up to 85 degrees. Since the transmission is already partially bad, i wouldn't change the fluid, but only top it up. Quote Link to comment
Rob W. Posted January 13, 2012 Report Share Posted January 13, 2012 Since the transmission is already partially bad, i wouldn't change the fluid, but only top it up. I'm not disagreeing but I wonder why you wouldn't change all of it?? Quote Link to comment
datzenmike Posted January 13, 2012 Report Share Posted January 13, 2012 Picked up the datsun. took her on the maiden journey of 500 miles. first 350 went reasonably well besides the tranny didn't want to come out of 5th very easy. any thoughts? I think you should have checked all fluids including the rear end first before driving 500 miles. Quote Link to comment
Yooperdatsun Posted January 13, 2012 Author Report Share Posted January 13, 2012 Mike: Roger! however I barely got 2 days off to go and pick the truck up so I figured I'd just run it. I don't think its the shifter itself. Quote Link to comment
ggzilla Posted January 13, 2012 Report Share Posted January 13, 2012 I wonder why you wouldn't change all of it?? Takes more time, will get a lot messier, cost more money for a transmission which the 5th gear is not working. Maybe by the time the weather warms up I'd decide to get a replacment transmission. If, not and going to keep this one then change the oil. That's my thinking today. Quote Link to comment
