Farmer Joe Posted April 7, 2008 Report Share Posted April 7, 2008 i was lookin at the engine in the truck and the head on the l20b block is a u67 head? is that stock for the l20? what did the u67 head come off of? thanks Quote Link to comment
Pacific coast Datsun Posted April 7, 2008 Report Share Posted April 7, 2008 http://www.the620.com then go to tech. section. Its all broken down there. Quote Link to comment
datsunaholic Posted April 7, 2008 Report Share Posted April 7, 2008 The U67 was the stock head for L20Bs in '75-77. Quote Link to comment
Farmer Joe Posted April 7, 2008 Author Report Share Posted April 7, 2008 The U67 was the stock head for L20Bs in '75-77. mkay! good to know. thanks!! Quote Link to comment
blueridgespeed Posted April 7, 2008 Report Share Posted April 7, 2008 The U67 is also (one of) the preferrd heads for doing an L-Z 2.2 type Frankenstein engine. If you want to do Nissan pistons, the KA24E (single cam, stock piston diameter 89mm) are still available, and you can bore a z22 block, use the crank from that block, and with the U67 head you still have a pump-gas amenable compression ratio. (Z22E or Z22s pistons were NLA a few years ago when I was doing a rebuild) I had a setup like this in my last 510, with Mikuni 44's and a custom cam from Malvern racing and I loved it. The U67 is a 'open chambered' head. The closed chambered heads have their advantages as well - more detonation resistant, etc. It's all on the links above. Quote Link to comment
Farmer Joe Posted August 3, 2008 Author Report Share Posted August 3, 2008 okay, bringin back an old post. is the u67 a square port or round port head? Quote Link to comment
240ADAM Posted August 3, 2008 Report Share Posted August 3, 2008 Its square port. Quote Link to comment
Farmer Joe Posted August 3, 2008 Author Report Share Posted August 3, 2008 mkay cool deal. gotta exchange my gasket then. damn NAPA... Quote Link to comment
