derricklong38 Posted December 22, 2011 Report Share Posted December 22, 2011 Need the bottom of the water outlet, the piece that holds the thermostat. Need it pretty quick, paypal ready! would love pics 2 bolts to head, 2 bolts to the top outlet, one 1/2" pipe hole, and one looks like 3/8" Link to comment
metalmonkey47 Posted December 22, 2011 Report Share Posted December 22, 2011 Do you need the top as well? Link to comment
derricklong38 Posted December 22, 2011 Author Report Share Posted December 22, 2011 Do you need the top as well? I guess I do, I am going to attempt to put a filler type outlet on it, but in case it cant be done I would need one. What do you have? Link to comment
datzenmike Posted December 22, 2011 Report Share Posted December 22, 2011 Thermostat housing. Link to comment
derricklong38 Posted December 22, 2011 Author Report Share Posted December 22, 2011 Thermostat housing. Thanks Datzenmike, been a while since i needed a piece like this Link to comment
metalmonkey47 Posted December 22, 2011 Report Share Posted December 22, 2011 PM sent.. Link to comment
ggzilla Posted December 22, 2011 Report Share Posted December 22, 2011 2-bolts to the top outlet? Make sure it has the temp sender BELOW the small coolant hose. If it has it ABOVE, swap the whole housing to the good kind. Link to comment
derricklong38 Posted December 22, 2011 Author Report Share Posted December 22, 2011 2-bolts to the top outlet? Make sure it has the temp sender BELOW the small coolant hose. If it has it ABOVE, swap the whole housing to the good kind. ggzilla, the top radiator hose is the highest point, it is a outlet on its own. The lower piece has 2 outlets. one on the bottom 3/8" sender, and one towards the dizzy 1/2" Link to comment
ggzilla Posted December 22, 2011 Report Share Posted December 22, 2011 That's the good kind, with sender below the small hose. There are 3 different housings for the L20B. Link to comment
derricklong38 Posted December 22, 2011 Author Report Share Posted December 22, 2011 good to know, thanks for the info! Link to comment
datzenmike Posted December 22, 2011 Report Share Posted December 22, 2011 That's the good kind, with sender below the small hose. There are 3 different housings for the L20B. Does that include the 3 bolt outlet? Link to comment
ggzilla Posted December 22, 2011 Report Share Posted December 22, 2011 Yes, the 3-bolt housing is the best one. The dealers used to put it on L20Bs that were marginally overheating and it fixed the problem. Of course you have to change both the housing and the outlet both. Link to comment
