L20B Thermostat Housing
  • Replies 11
2-bolts to the top outlet? Make sure it has the temp sender BELOW the small coolant hose. If it has it ABOVE, swap the whole housing to the good kind.
ggzilla, the top radiator hose is the highest point, it is a outlet on its own. The lower piece has 2 outlets. one on the bottom 3/8" sender, and one towards the dizzy 1/2"
