atkinson40 Posted December 19, 2011 Report Share Posted December 19, 2011 I can hear and smell an exhaust leak around the exhaust manifold area. When its cold I've felt at the junction of the manifold/muffler tube and can't feel anything. Any known areas before I take off the air filter and start looking at the exhaust manifold area? For troubleshooting I'm thinking of putting a tiny feather from a duster on the end of a stick and probing around until I see it being blown. Any other ideas? Thanks Kevin Quote Link to comment
ggzilla Posted December 19, 2011 Report Share Posted December 19, 2011 The standard method is to use a hose to your ear, and move the other end around the manifold. You will find exactly where the noise is coming from. You can use a length of heater hose, washer drain hose or garden hose. Don't remove the intake manifold. Quote Link to comment
banzai510(hainz) Posted December 19, 2011 Report Share Posted December 19, 2011 what I do is put my hand under the intake exhaust manifold and feel for hot air comming out. Plus it stinks like you say. I notice if you have the exhaust side of the bolts fall out it will lossen up but still drive and blow out/crack the center 2 holes in the exhaust manifold Quote Link to comment
atkinson40 Posted December 20, 2011 Author Report Share Posted December 20, 2011 The standard method is to use a hose to your ear, and move the other end around the manifold. You will find exactly where the noise is coming from. You can use a length of heater hose, washer drain hose or garden hose. Don't remove the intake manifold. Thanks GG. Exactly what I was looking for. -K Quote Link to comment
