unseen Posted December 18, 2011 Report Share Posted December 18, 2011 hey ratsuns We're so close to having this 521 operational !!! any help greatly aPPRECIATED ! today, We started her up and found a loud air sound at the carb, but we cant pinpoint where exactly its coming from? thank you :) Quote Link to comment
I'm BLUE Posted December 18, 2011 Report Share Posted December 18, 2011 Cool ,,, keep moving forward ,,, Look for any vacuum leak ,,, check intake manifold gasket ,,, around 8-15ft lbs ( Don't quote me ) ,,, adapter plates on weber carbs can leak if not tightened properly ,,, carbs need around 5-8ft pounds of torque ,,, no more or it will warp baseplate ,,,, check all hoses are intact ,,, and placed properly good luck :) Quote Link to comment
Guest 510kamikazifreak Posted December 18, 2011 Report Share Posted December 18, 2011 Cool ,,, keep moving forward ,,, Look for any vacuum leak ,,, check intake manifold gasket ,,, around 8-15ft lbs ( Don't quote me ) ,,, adapter plates on weber carbs can leak if not tightened properly ,,, carbs need around 5-8ft pounds of torque ,,, no more or it will warp baseplate ,,,, check all hoses are intact ,,, and placed properly PCV hooked up? good luck :) fixed Quote Link to comment
ggzilla Posted December 18, 2011 Report Share Posted December 18, 2011 Air cleaner on? If not it makes a loud air sound. Quote Link to comment
KC Phirus Posted December 18, 2011 Report Share Posted December 18, 2011 ITS THE VTEC YO If your air cleaners off it's gonna sound like a vacuum cleaner. Dunno what engine or if 521's had any smog but check for leaks around smog bs. Quote Link to comment
