straycat60 Posted April 3, 2008 Report Share Posted April 3, 2008 hi, i recently picked up a 1965 320. i am trying to get a rebuild kit for the nikki carb. or is there another carb that would swap out ? any info would help. mike Quote Link to comment
Pacific coast Datsun Posted April 3, 2008 Report Share Posted April 3, 2008 Ive seen the kits on ebay every now & then. You could probably use a WEber if the right adapter plate was ever made. You may try taking yours apart & giving it a good cleaning w/ carb spray & or soak the parts in parts cleaner [remove gaskets 1st] then reinstall & see how it runs. Quote Link to comment
datsunfreak Posted April 4, 2008 Report Share Posted April 4, 2008 If you had posted this in the truck forum you might get more response... ;) Quote Link to comment
