Will Posted November 18, 2011 Report Share Posted November 18, 2011 I swapped a different grille into my 710, and since there isn't space for the original turn signals I figured that I'd wire up an old pair of fog lamps (with different bulbs) as my turn signals. After the fog lamps arrived in the mail I noticed that the turn signal/parking lamps have two filaments and two conductors on their base (like the bulb to the right in the photo), and the fog lamps have only one conductor/filament. (like the bulb to the left in the photo) Does anyone have any suggestions about how I can get the fog lamps to work as turn signal/parking lamps? I thought maybe I could just switch the wiring over, but the 2-conductor wiring needs a different type of socket to keep the 2 conductors in the right place for the bulb. Quote Link to comment
datzenmike Posted November 18, 2011 Report Share Posted November 18, 2011 Don't think so Will. You would have to swap the dual socked over onto the fog lamp and silicon it in place. Quote Link to comment
Will Posted November 18, 2011 Author Report Share Posted November 18, 2011 Yeah... I checked, and on the two-conductor bulb the bayonet pins are at different heights, so the bulb won't fit in the socket, even if I file slots in the socket so that the conductors won't rotate. I'm guessing that if I just twist the two green conductor wires together I'll end up with turn signals that don't work whenever my headlights are on, right? Quote Link to comment
ggzilla Posted November 18, 2011 Report Share Posted November 18, 2011 It's not about the headlights, instead the 2nd filament is for the running lights (parking lights). Why not install four foglamps. Outer ones for T/S, inner ones for running lamps. Quote Link to comment
Will Posted November 19, 2011 Author Report Share Posted November 19, 2011 I managed to solve the problem with a hacksaw, rat-tail file and some epoxy. I cut the sockets off of the original turn signals and made them fit in the old fog lights I bought on ebay. I was even able to re-use the old holes for the US grille to mount the fog lights. Maybe I should have used some larger fog lights? Quote Link to comment
