RedBanner Posted November 15, 2011 Report Share Posted November 15, 2011 so ive read as many post as I can, both here and abroad, and im just not satified. I want to build a good a series, and a local guy passed a messege to me second hand saying delsol pistons could be subbed for a14 pistons for cheap flat top or dome, as the a series ones are 1000 bucks. I intend on spending my bonus on building a dependable motor, built but within the parameters enuff that i dont have to worry about poppin the head gasket at the time, or tacoing rods and such. I assume to hear " a15 with flat top pistons , closed chamber head, side drafts". So bring it on, and since I thread withour pics is broken, I found these durring my web search Quote Link to comment
ggzilla Posted November 15, 2011 Report Share Posted November 15, 2011 I can recommend what I have * A14 overbored from 76mm to 78.5mm -- total 1492cc (larger than an A15) * Closed chamber H89 head (JDM/AUS head) ported * Twin Mikuni/Solex * Flat-top pisons, about 10.5:1 compression (requires premium gasoline) * EE Custom header with a turbo muffler * Unknown camshaft. It runs best over 3,000 RPM but will putter around at 1500. You don't have to buy the Tomei pistons for $1000. You can buy custom pistons from Arias and other US piston companies for about $100 each. Since they are custom, you have to call them. There's no replacment for displacement. I'd go with 79mm pistons and an A15 block & crank. For about 1600cc. Call Isky and have them grind you a camshaft for 3000-6000 RPM use. Be sure to use some low gear like 4.11 -- or use stock gear with small diameter tires like 195/50R15. Gotta keep the revs up for a high revvin engine. Quote Link to comment
ggzilla Posted November 15, 2011 Report Share Posted November 15, 2011 Some guys like high compression. But going up to 10:1 will only gain you 2% power. Going from 76mm to 79mm will give you around an 8% power gain. I'd go with an A15 and 79mm pistons. here's my engine. twin Sidedrafts look cool, but you may need to use a remote brake reservoir on a LHD model. Not move the brake cylinder, just move the reservoir. 1 Quote Link to comment
king bee66 Posted November 15, 2011 Report Share Posted November 15, 2011 how about the guy selling the a19 with a header and 5speed for 600$ just need to buy the mikunis and a mani. also i think if you go with an r1 set up they will lift above the master cylinder Quote Link to comment
RedBanner Posted November 15, 2011 Author Report Share Posted November 15, 2011 Im in search of a closed chamber head, as for carbs, would one big webber side draft keep up you think? All the side draft shit is crazy expensive, thinking hard at this point. But im leaning towards .... Well idk, well see what pops up first. Quote Link to comment
ggzilla Posted November 15, 2011 Report Share Posted November 15, 2011 Two webers only cost about twice a single weber. So it's only 2x crazy. But I'd get the Mikuni/Solex carbs. They are by far the most popular in Japan and were the ones sold by Nissan Competition. The $600 engine already has all these parts, even if you need to rebuild it it might be worth it. Quote Link to comment
RedBanner Posted November 15, 2011 Author Report Share Posted November 15, 2011 If I get 6 bills before it sells im going to hop al over it. As for webbers being the less popular, so the makunis are going to be cheaper, or better? Quote Link to comment
DRIVEN Posted November 15, 2011 Report Share Posted November 15, 2011 I always thought this one was cool. Ggzilla could probably give us an update on this one. It was stock bottom end with good pistons IIRC. http://community.ratsun.net/topic/10311-supercharged-a15-in-datsun-1200/ Quote Link to comment
ggzilla Posted November 15, 2011 Report Share Posted November 15, 2011 Yes, a stock A15 with stock pistons. Only the valve springs were changed to allow 8500 RPMs It had twin Weber 32/36 and a Mercedes 230 supercharger Quote Link to comment
