ol' 320 Posted October 31, 2011 Report Share Posted October 31, 2011 Howdy. One of you fine chaps probably knows exactly what the part number is for a reverse light switch that fits into a dogleg 5 speed. I recently bought a 320 p/u with a A12 engine installed with a dogleg trans. When we rewired this truck, there was no reverse light switch. I'd like to source one, or at least a part number for one (and possibly a picture of one). Also, if anyone has a part number for a 510 two speed wiper switch, I want to change out my current one speed wiper switch with a two speed switch. I'm also going to try to set this old 320 up with intermittent wipers, if anyone has some bright ideas as long as I'm changing the switch. Thanks in advance. Quote Link to comment
ol' 320 Posted October 31, 2011 Author Report Share Posted October 31, 2011 I found the backup light switch numbers. Ordered from Rock Auto, using a code from Ratsun... thanks! For reference: Part Numbers K1232005-K121A Rev Lamp B110 $33.70 USDUsed by all Datsun 1200Most 60-series 4-speeds B210/B310FSW560L 60-series 'dogleg' 5-speed B310Some FSW560A 60-series 5-speed B310Also used in early 4TH-gear switch (USA B110)Aftermarket* BWD S9254 (w/spade terminals)* ACDelco E2202* ACDelco E2228D* Master Pro 2-8943 (w/bullet terminals)* Original Engine Management 8943* Standard Motor Product/Intermotor LS325* AirTex/Wells 1S5440Back Up Lamp Switch (This is the one I ordered from Rockauto today's date. K10 32005-K102A Switch Rev Lamp $36.47 Used by some FSW560A 60-series 5-speed B310Alternate OEM Part Numbers: 32005-K100132005-K100432005-K102A32005-M020032005-M210588923307JA44232005-2100032005-K1004Aftermarket* ACDelco E2204 * KEMParts NS157$7.56 USD* Original Engine Management 8999 (w/spade terminals)* AirTex/Wells 1S579256-seriesfits various56-series, 60-series, 63-series and 71-series* A12A/A14/A15* L16/L18/L20B* L24/L24E/L26/L28E/L28ET/LD28 Diesel* E15* Z20/Z22/Z22* SD22/SD25 DieselBackup Lamp Switch for A10/A12 powered vehicles. 32005-K121A Rev Lamp B110 $33.70 USD FS4W56Lsupeceded 32005-H5000 COMP-SWITCH REVERSE LAMP replaced 32005-21101 COMP-SWITCH REVERSE LAMPreplaced 32005-21100 COMP-SWITCH REVERSE LAMPAlso used in early 4TH-gear switch (USA B110)* BWD S9254 (w/spade terminals)* ACDelco E2202* ACDelco E2228D* Master Pro 2-8943 (w/bullet terminals)B120 Datsun 1200 Pickup32005-21000 SWITCH COMP.-reverse lamp 3 speed32005-21100 SWITCH COMP.-reverse lamp 4 speed32005-21101 SWITCH COMP.-reverse lamp 4 speed32010-G1651 -8910 B120 FSW56Areplaced 32005-21101 SWITCH ASSY-REVERSE LAMPB10 Datsun 100032005-21100 ASS'Y-SWITCH, reverse lamp 4 speed32005-21000 ASS'Y-SWITCH, reverse lamp 3 speedreplaced (not interchangeable) 25310-89900 ASS'Y-SWITCH, reverse lamp 3-speed32108-18100 PLUG-reverse lamp switch (up to '68-Sept.)60-Series32005-K121A Switch Rev Lamp $33.70 USDsuperceded 32005-K1202 SWITCH COMP-REVERSE LAMP 4-SPEED(A12) B310superceded 32005-K1201superceded 32005-H50004-speed superceded 32005-K1202 SWITCH COMP-REVERSE LAMP 4-SPEED(A14,A15) B310superceded 32005-K1201superceded 32005-H50005-speed 32005-K121A Switch Rev Lamp $33.70 USD superceeded 32005-K1202 SWITCH COMP-REVERSE LAMP B310 -0779 [FS5W60L 'dogleg']superceeded (interchangeable) 32005-K1201superceeded (interchangeable) 32005-H5000 32005-K1000 SWITCH COMP-REVERSE LAMP B310 -0779 [FS5W60L 'dogleg'] 32005-K121A Switch Rev Lamp $33.70 USDsuperceeded 32005-H5000 SWITCH COMP-REVERSE LAMP B310 0879- [FS5W60A] replaced (not interchangable) 32005-K100032005-K102A Switch Rev Lamp $36.47 superceded 32005-K1002 SWITCH COMP-REVERSE LAMP B310 0879- [FS5W60A] superceded (interchangeable) 32005-K1001superceded (interchangeable) 32005-K1000 63-seriesFor B210 5-speed, which debuted April 1976 (1976-1/2 model year) 32005-K102A Switch Rev Lamp $36.47 superceded 32005-K1000 COMP-SWITCH,REVERSE LAMP 5-SPEED(COUPE) B210 0476- Quote Link to comment
izzo Posted October 31, 2011 Report Share Posted October 31, 2011 I can't remember the part number. But i brought one into Napa auto parts, they looked thru their book and found me one. It was around 10 dollars. Quote Link to comment
datzenmike Posted October 31, 2011 Report Share Posted October 31, 2011 Any '74 and up 4 or 5 speed truck, 280z, Maxima reverse light switch is the same number 32005-K1000 Quote Link to comment
