Draynor Posted October 26, 2011 Report Share Posted October 26, 2011 Will a l20 out of a 1976 620 5 speed, bolt up to my 1971 510 automatic transmission? Thanks Derek. Quote Link to comment
datzenmike Posted October 26, 2011 Report Share Posted October 26, 2011 Yes it will bolt up, but not to the 510's 5 bolt flex plate. If you can find an L20B 6 bolt 3N71B automatic flex plate it might work. '71 was the year that the 510 switched to the 3N71B automatic. I would say that if it's got a 3N71B in it it will work. If the 510 has an earlier Borg Warner auto there may be too many differences. Quote Link to comment
Draynor Posted October 26, 2011 Author Report Share Posted October 26, 2011 Thanks for the reply. Do you know where i could get the 6 bolt flex plate? Its the stock auto trans out of the 71 510 Quote Link to comment
Draynor Posted October 26, 2011 Author Report Share Posted October 26, 2011 Yes it will bolt up, but not to the 510's 5 bolt flex plate. If you can find an L20B 6 bolt 3N71B automatic flex plate it might work. '71 was the year that the 510 switched to the 3N71B automatic. I would say that if it's got a 3N71B in it it will work. If the 510 has an earlier Borg Warner auto there may be too many differences. Will I also need a 6 bolt flex plate for a L16 or L18 swap? Quote Link to comment
zerow Posted October 26, 2011 Report Share Posted October 26, 2011 Will I also need a 6 bolt flex plate for a L16 or L18 swap? L16s and L18s have a five bolt flexplate, so no you will not need it if you plan for either the L16 or L18. Don't forget that the L20B is a taller motor than the L16 or L18, so there could be a hood clearance problem as well. Quote Link to comment
Draynor Posted October 26, 2011 Author Report Share Posted October 26, 2011 L16s and L18s have a five bolt flexplate, so no you will not need it if you plan for either the L16 or L18. Don't forget that the L20B is a taller motor than the L16 or L18, so there could be a hood clearance problem as well. I was looking into any of the L series engines for my 71 510 automatic 4 door, it came with no engine, Im trying to figure out what im looking at thanks for the help guys. Yeah i know about the clearance issues with the l20b Quote Link to comment
datzenmike Posted October 26, 2011 Report Share Posted October 26, 2011 '71 was the year that the 510 switched to the 3N71B automatic. I would say that if it's got a 3N71B in it it will work. If the 510 has an earlier Borg Warner auto there may be too many differences. Don't forget... there may be issues with compatibility if you use a 3N71B flex plate on an earlier Borg Warner automatic. You need to identify the transmission you have. Does it have this on the back? Does it have a floor shift? . Quote Link to comment
Draynor Posted October 26, 2011 Author Report Share Posted October 26, 2011 Don't forget... there may be issues with compatibility if you use a 3N71B flex plate on an earlier Borg Warner automatic. You need to identify the transmission you have. Does it have this on the back? Does it have a floor shift? . It is a column shift, and it does not have that badge. Quote Link to comment
