Dawgz83948 Posted October 22, 2011 Report Share Posted October 22, 2011 I need the Thermostat housing (the lower portion) for the L20b. I need the thermo switch (does not have to be good just not leak) the nipple for the return and the hole for the temp sensor. I also need the alternator mount for the L20b. Link to comment
Guest kamakazi620 Posted October 22, 2011 Report Share Posted October 22, 2011 I need the Thermostat housing (the lower portion) for the L20b. I need the thermo switch (does not have to be good just not leak) the nipple for the return and the hole for the temp sensor. I also need the alternator mount for the L20b. Junkyard or Ebay YO!! Link to comment
datzenmike Posted October 23, 2011 Report Share Posted October 23, 2011 Mover to Parts Wanted.... you'll get more views here. Link to comment
Dawgz83948 Posted October 24, 2011 Author Report Share Posted October 24, 2011 Mover to Parts Wanted.... you'll get more views here. Thanks. I realized my mistake after. Sorry. Link to comment
datzenmike Posted October 24, 2011 Report Share Posted October 24, 2011 I only mention it so other noobs may read it Link to comment
Radiant-Designer Posted October 24, 2011 Report Share Posted October 24, 2011 I have these if you need them. ill get pics for you. 2 bolt or 3 bolt? Send me a message Link to comment
Chris#51EPGraham Posted October 25, 2011 Report Share Posted October 25, 2011 I still have all three of these. None are from L20b but one may be the style you need. Differences: one has no crossover port, one has 1/8" NPT crossover port, one has 1/4" NPT crossover port. All are cleaned up with gasket surfaces lapped, good holes and threads, no cracks. Any of these = $27 shipped. http://www.flickr.com/photos/50853885@N06/5248166195/in/set-72157624202328584 http://www.flickr.com/photos/50853885@N06/5248166193/in/set-72157624202328584 I can't seem to find thermos switches - have some, but gotta look for them. Link to comment
Dawgz83948 Posted October 25, 2011 Author Report Share Posted October 25, 2011 I still have all three of these. None are from L20b but one may be the style you need. Differences: one has no crossover port, one has 1/8" NPT crossover port, one has 1/4" NPT crossover port. All are cleaned up with gasket surfaces lapped, good holes and threads, no cracks. Any of these = $27 shipped. http://www.flickr.co...157624202328584 http://www.flickr.co...157624202328584 I can't seem to find thermos switches - have some, but gotta look for them. I don't really need the thermo switches, but for some reason the L16 housing I have currently does not work. The L20b's were slightly different. Link to comment
420n620 Posted October 25, 2011 Report Share Posted October 25, 2011 in group #4, the left one, how much $. http://www.flickr.com/photos/50853885@N06/6264963067/in/set-72157624202328584/ Link to comment
Chris#51EPGraham Posted October 25, 2011 Report Share Posted October 25, 2011 in group #4, the left one, how much $. http://www.flickr.com/photos/50853885@N06/6264963067/in/set-72157624202328584/ Oh sh**t...sorry 420, it looks like I sold that one. Link to comment
Chris#51EPGraham Posted October 25, 2011 Report Share Posted October 25, 2011 I don't really need the thermo switches, but for some reason the L16 housing I have currently does not work. The L20b's were slightly different. What's wrong with your current housing? As you can see from mine, the NPT thread size for the crossover nipple can be 1/4" or 1/8" or there can be no crossover fitting at all ('69 L16, I think). Replacement brass NPT nipples can be had for the correct hose diameter regardless of which NPT thread. I also have a few of the original brazed steel ones in various size combos and will be happy to measure to try to match what you've got. The temp sender threadings appear to be the same on all. One of mine may be from a '74 L20b or a '73 L18, not sure. I can measure hole center and flange dimensions if that would be helpful. I'm not familiar with specific differences between L20b and L16/L18 and definitely want to know if anyone can edify me on this. Got digital calipers. Gasket surface leaks can be caused by warpage or corrosion. This is easy to fix by lapping flat on 80 - 100 grit sandpaper on plate glass (or any reliably flat table surface). These housings can be cracked. I've seen them cracked through the temp sender boss and in the long mounting holes where rust caused a bolt to break and get stuck. Link to comment
420n620 Posted October 25, 2011 Report Share Posted October 25, 2011 Oh sh**t...sorry 420, it looks like I sold that one. Oh darn, are the other 2 the same length ? What is the measurement. Thanks bump-titty bump. :blush: Link to comment
Dawgz83948 Posted October 26, 2011 Author Report Share Posted October 26, 2011 What's wrong with your current housing? As you can see from mine, the NPT thread size for the crossover nipple can be 1/4" or 1/8" or there can be no crossover fitting at all ('69 L16, I think). Replacement brass NPT nipples can be had for the correct hose diameter regardless of which NPT thread. I also have a few of the original brazed steel ones in various size combos and will be happy to measure to try to match what you've got. The temp sender threadings appear to be the same on all. One of mine may be from a '74 L20b or a '73 L18, not sure. I can measure hole center and flange dimensions if that would be helpful. I'm not familiar with specific differences between L20b and L16/L18 and definitely want to know if anyone can edify me on this. Got digital calipers. Gasket surface leaks can be caused by warpage or corrosion. This is easy to fix by lapping flat on 80 - 100 grit sandpaper on plate glass (or any reliably flat table surface). These housings can be cracked. I've seen them cracked through the temp sender boss and in the long mounting holes where rust caused a bolt to break and get stuck. The L20b has a relief nipple above the temp sensor to keep water flowing. The issue I'm having is that the dash gauge and an aftermarket electric gauge both show the engine running hot, however once you remove the radiator and hit it with an IR thermometer it is running at 180*. Best guess is because the l20b needs that crossover to be there.Looks like someone already has what Ineed though. Thanks again. Anyone have that other part I need :) Link to comment
Dawgz83948 Posted October 27, 2011 Author Report Share Posted October 27, 2011 I also need the wire clips for the HVAC system. Mine is missing a few. I have the one for the heater valve. My truck is a 1974. Link to comment
Bentaxlebob Posted November 23, 2012 Report Share Posted November 23, 2012 This Thread ( year old ) answers my posted and unaswered question in my thread. I can see the ports and the probability of fitting a temp sensor ( mechanical gauge ). Which wa ythe thermostat opens if anyone knows? I do not remember. Planing on using a mechanical sensor on one of the 2 frontal additional ports ( now plugged in in my L20B ) . The lower side port is for the stock temp sensor which I will keep as additional and complementary temp monitoring device. Do not want the sensor ( SunPro ) to interfere with the thermostat operation. Link to comment
ajen68510 Posted November 24, 2012 Report Share Posted November 24, 2012 still looking for a thermostat housing ? I have 2 Link to comment
