Tuan Posted October 18, 2011 Report Share Posted October 18, 2011 Okay, so after doing the brakes, and cooling, the damn Electrical components take a shit. You've got to be kinding....................!!! So I told you guys I was going to fiberglass a custom dash, well I tried and failed. I had used some styro foam left over from packaging and wrapped the entire dash with packaging clear wrap. So it was very promising and I laid Fleece over it and could see the general shape. Well, I laid fiberglass resin over it and the heat of the mixture pretty much ate through the plastic wrap and eat away at the styrofoam. Well, it was a good and cheap try at that. The dash came out okay, but there was just too much work involve to get it perfect. So I opted out and went with aluminum. aluminum dash, Straight forward, and I also bypassed the ignition switch and rockin' switches and just ordered a push start button. I wasn't going to spend $100 on a new ignition switch so $20 worth of toggle switches and a push start button will sure do it. OOooo, rocking stock gagues. I had to make custom mounts for them, but sure is easy. LED's making the gauges visible at night. The Aluminum dash took me 1 hour or so, a couple of bends and jigsawed it and that was that. Still have to sand and clean up the aluminum a bit, probably put suede or carpet dash mat or Curbin FUrberr, or something cool. Still gotta make the end caps for the dash, but the hard parts are done. Boso Exhaust next? Hmmmm.........Time will tell. The cente console will be aluminum as well, that's eaaaaaaaasy cheesy. sTAY TUNED. Quote Link to comment
ninjabortion Posted October 18, 2011 Report Share Posted October 18, 2011 looks good man, i went with license plates on mine haha Quote Link to comment
Tuan Posted October 19, 2011 Author Report Share Posted October 19, 2011 looks good man, i went with license plates on mine haha Hahaha, you crazy son! That's cool. I say, you should do a dash with the old year Tags and Months. Have like 500 stickers from all the years and months. Good stuff, work with what you got. Quote Link to comment
sbZ Posted December 9, 2011 Report Share Posted December 9, 2011 That's bad ass dude! Any chance you can give me the dimensions for the aluminum? I have an extra dash and I really wanna try this. Edit: Hadnt seen your intro thread before :rolleyes: Quote Link to comment
hollywood7600 Posted December 9, 2011 Report Share Posted December 9, 2011 Since you were working with fiberglass you should have put aluminum foil over the plastic wrapping and styro foam. It will not dissolve the aluminum foil and it will give the shape that you desire. Best people to ask for fiberglass advice are the body shop, and stereo installers. Quote Link to comment
