sam Posted October 14, 2011 Report Share Posted October 14, 2011 I have a 510 l20b with dual su . I have a universal wiring harness and I ha e no clue where to start and want is needed to run the car. Can I please get some guidance in how wire I need to drive the car pleaseeeee Quote Link to comment
sycloned916 Posted October 14, 2011 Report Share Posted October 14, 2011 It shouldn't be to hard to wire it up,you could go off of you old harness if you still have it or follow a wire diagram. Is it a full wire harness for your whole car or just a harness for the engine and ignition/start. Power, key-on and start is all you should need to run that L20b. I would have someone help just in case,you don't want your car catching Fire. It's not that bad. Good Luck! Quote Link to comment
Duncan Posted October 14, 2011 Report Share Posted October 14, 2011 I have a 510 l20b with dual su . I have a universal wiring harness and I ha e no clue where to start and want is needed to run the car. Can I please get some guidance in how wire I need to drive the car pleaseeeee Every one of those aftermarket manufacturers have a website where you can download the manual. I've looked at most of them. Which one do you have? Quote Link to comment
