F/S 1981 210 Hatch Deluxe $1400
Because I'm sick of dealing with all the low balling, half wit morons in GA, I'm finally posting it here.
I need it sold ASAP to go pick up my new project, since I don't have room on insurance for both.
Ratsun price is FIRM @ $1400. Link to my CL add is below.
http://atlanta.craig...2629423702.html
Any Ratsuner gets a 4 speed Z20 tranny and my LZ20 engine project with the car.
--New ball joints/tie rod ends/idler arm/ poly sway bar bushings
--New shocks/bled struts and lowered in the front
--Top end rebuild 10K miles ago with new headgasket, OEM Nissan head bolts, valve seals, and was ported to allow the head to breath better.
--Equipped with a freshly rebuilt 32/36 Weber DGV carb
--Electronic ignition and MSD ignition box with coil and Accel 8MM wires on NGK BPR6ES plugs
--Tires 85% tread and freshly balanced ZX turbo 6 spoke Aluminum rims
--Fresh water pump and flushed block
--Runs great and does about 30 MPG on a rough day!
--Clutch and all related parts were replaced 2 weeks ago including master and slave.. Trans filled with fresh GL4
--New brakes/hydraulics all around including calipers/wheel cylinders and all hardware.
--Weighs in under 2000lbs with two passengers
--300ZX Z31 power seats with harness bar/Simpson cam lock harness
--Straight piped on freshly bent/welded exhaust.
--Fresh Optima 34R Red top.
--Needs turn signal switch
_DSC0085_6_7 by metalmonkey47, on Flickr
_DSC0295[1] by metalmonkey47, on Flickr
  • Replies 7
HDR of the engine bay is sweet! GLWS :)
I'm going to donate some Buick stick on fender holes to enhance the sale, that will get the boys in ATL interested!
And some 22'' spinner rims dawg! That will get the georgians interested :rofl:
