lower body only
sicAsic
  • Replies 5
i am still unhappy with the results after lowering the entire truck and airbag is my last resort. wanted to inquire the amount of work involve and how low would it be by lowering the body. thank you for your assistance.
Man that is a hell of alot of work to body drop a truck just to get a few inches lower. I would say airbag it , like the last guy said.. Body dropping is alot of cutting and fab work..But if you have the means and knowledge...go for it.... Check " Beebani" he has a whole build of bagging his truck on this site..good luck!!
To properly body drop a truck will require the interior to be gutted,,firewall & rear of cab sections removed & sectioning the front 2 body mounts / entire front frame section down, among other things :D If youve gone that far go ahead & install the air bags. Most shops will charge $3500-$6000 to do both. It can be done at home but its alot of work.
