rockstar 620 Posted September 13, 2011 Report Share Posted September 13, 2011 well im still tryin to get my truck running and i was wondering if i can make a separate wiring for my distribuitor and maybe coils on my z24 engine. any helps appreciatted thx in advance !! Quote Link to comment
rockstar 620 Posted September 13, 2011 Author Report Share Posted September 13, 2011 i think i just posted this in the wrong section...sry!! Quote Link to comment
Wide14u Posted September 13, 2011 Report Share Posted September 13, 2011 this was up in a thread but the thread vanished datzen mike can tell us Quote Link to comment
rockstar 620 Posted September 13, 2011 Author Report Share Posted September 13, 2011 hope so!! i did sum reasearch i couldnt find nething... Quote Link to comment
Wide14u Posted September 13, 2011 Report Share Posted September 13, 2011 is your distributor a 3 wire or 4 wire Quote Link to comment
Sealik Posted September 13, 2011 Report Share Posted September 13, 2011 Z24 in the 81? Won't start...no spark? 3 or 4 wire dizzy will work Quote Link to comment
Wide14u Posted September 13, 2011 Report Share Posted September 13, 2011 inside the distributor the wire that comes off the b terminal goes to the + on both coils and c goes to the - of one of the coils and e goes to the other neg if i remember right but wait for mike or someone better to confirm this Quote Link to comment
rockstar 620 Posted September 14, 2011 Author Report Share Posted September 14, 2011 its actually a 85 z24 and its a 4 wire dist. dual coils. Quote Link to comment
Wide14u Posted September 14, 2011 Report Share Posted September 14, 2011 you wont use the fourth wire Quote Link to comment
rockstar 620 Posted September 14, 2011 Author Report Share Posted September 14, 2011 so power goes in and b and c terminals back to coils and thats all?? no relays or anything needed?? Quote Link to comment
Wide14u Posted September 14, 2011 Report Share Posted September 14, 2011 b goes to the positive on both coils Quote Link to comment
rockstar 620 Posted September 14, 2011 Author Report Share Posted September 14, 2011 sweet and i can fire up the dist off the ignition switch correct?? Quote Link to comment
datzenmike Posted September 14, 2011 Report Share Posted September 14, 2011 What's this going in? Quote Link to comment
rockstar 620 Posted September 14, 2011 Author Report Share Posted September 14, 2011 its in my 620/720 85 720 frame n drivetrain 76 620 cab Quote Link to comment
Wide14u Posted September 14, 2011 Report Share Posted September 14, 2011 What's this going in? why would it change depending what it goes in Quote Link to comment
rockstar 620 Posted September 14, 2011 Author Report Share Posted September 14, 2011 well could i use the old coil wire to power the distribuitor?? im just trying to keep it as simple as possible and im not all that that whenit comes to wires. Quote Link to comment
rockstar 620 Posted September 15, 2011 Author Report Share Posted September 15, 2011 so i decided to pull all the tape off the old 720 harnes and i puled the distribuitor and coil harnes from what i can see it looks like a big brown wire is what power this up coming from a relay...can i use the coil wire on the 620 harness and hook it to this brown wire im talkin about or should i hook the old coil wire before the relay?? Quote Link to comment
