usmc210 Posted September 4, 2011 Report Share Posted September 4, 2011 Took off my carb today, left the fuel lines on just undid the bolts and throttle. Now when I turn it on it idles real high then dies. No obvious vacuum leaks and I didn't touch the adjusting screws, all the throttle is not stuck either. Any ideas ? Quote Link to comment
datzenmike Posted September 4, 2011 Report Share Posted September 4, 2011 This begs the question... why did you remove the carb? 1 Quote Link to comment
510kevin Posted September 4, 2011 Report Share Posted September 4, 2011 This begs the question... why did you remove the carb? roger that. what was the problem in the first place? is it a weber? did you put a new gasket underneath the carb? details, details, DETAILS!!!! :P Quote Link to comment
usmc210 Posted September 4, 2011 Author Report Share Posted September 4, 2011 No new gasket, stock carb, I was seeing if the adapter plate my friend gave was the right one to mount my weber Quote Link to comment
DAT510 Posted September 5, 2011 Report Share Posted September 5, 2011 if nothing in the carb maybe the linkage? Quote Link to comment
usmc210 Posted September 5, 2011 Author Report Share Posted September 5, 2011 Fix it, must have been a leak just took it off put it back on Quote Link to comment
