any 510's in SACRAMENTO area??
doughboi916
  • Replies 12
Yup Laecaon exactly what i had in mind.. i just dont know what it is man??? i know i got the Can/Am box wired rite.. alt and starter im still iffy on.. ive follwoed what you told me and tried various other things... i think ill be able to get it if i had a look at another swap.
Im gonna go back to that thread. Follow me there.
  • 1 month later...
no prob brotha!!.. i havent had much time to work on it lately.. but maybe next week ill be free.. any way you think i can come check out your setup?? is it running?? just want to snap a few pictures for reference... i can get it running with starter fluid.. i rigged up fuel lines out of a gas can to test it but nothing... fuels flowing and coming back out the return..?? even with starter fluid it idles fine and runs for 30 seconds..
should be easy to diagnose. What PSI are you running at your FPR? When you try to start it does it try to start, stumble and then die? Or does it just spin? When you try this are your plugs wet? If you are getting fuel flowing back into the temp can from the return line then fuel is going through the rail so it sounds like maybe your injectors are not spraying, even if they were spraying at the wrong PSI it should still start up and at least stumble. Dumb question but you have installed the injector harness right?
